Ana içeriğe geç
Dell Inspiron 14R-5421 Keyboard Replacement
Neye ihtiyacın var
  1. Dell Inspiron 14R-5421 Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Push the two sliders away from the battery towards the outer edges.
  2. Dell Inspiron 14R-5421 Keyboard Replacement: adım 2, 2 resimden 1. Dell Inspiron 14R-5421 Keyboard Replacement: adım 2, 2 resimden 2.
    • Remove the battery when it pops up.
  3. Dell Inspiron 14R-5421 Keyboard Replacement, Keyboard: adım 3, 1 resimden 1.
    • Find the clips on the keyboard. They are shown by red arrows.
  4. Dell Inspiron 14R-5421 Keyboard Replacement: adım 4, 1 resimden 1.
    • Using a pry tool, detach the 9 clips from the keyboard by prying at a 90 degree angle.
    • Be careful while detaching and do not lift the keyboard too high or be too rough. The keys can break easily and there is a fragile ribbon cable beneath the keyboard.
  5. Dell Inspiron 14R-5421 Keyboard Replacement: adım 5, 1 resimden 1.
    • Carefully disconnect the ribbon cable from the socket and pull apart.
    • The cable could be connected to other components of the laptop. Proceed with caution because the cable is fragile.
Sonuç
Jared paiva
489 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S4-G4, Covino Spring 2018 UMass Dartmouth, Team S4-G4, Covino Spring 2018 üyesi
UMASSD-COVINO-S18S4G4
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 571
