Ana içeriğe geç
Dell Inspiron 14R-5421 RAM Replacement
Neye ihtiyacın var
  1. Dell Inspiron 14R-5421 RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Push the two sliders away from the battery towards the outer edges.
  2. Dell Inspiron 14R-5421 RAM Replacement: adım 2, 2 resimden 1. Dell Inspiron 14R-5421 RAM Replacement: adım 2, 2 resimden 2.
    • Remove the battery when it pops up.
  3. Dell Inspiron 14R-5421 RAM Replacement, RAM: adım 3, 1 resimden 1.
    • Unscrew the cover from the laptop using a Phillips #0 screwdriver.
    • Remove the cover hiding the internal components by sliding it down.
  4. Dell Inspiron 14R-5421 RAM Replacement: adım 4, 1 resimden 1.
    • Lift the ram module up then pull it out of its slot.
    • Be sure to place the new ram module back into the same slot. Only put a module into slot DIMM B if you have a second working module you want to use.
Sonuç
Jared paiva
489 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S4-G4, Covino Spring 2018 UMass Dartmouth, Team S4-G4, Covino Spring 2018 üyesi
UMASSD-COVINO-S18S4G4
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 14
Her zaman: 383
