Ana içeriğe geç
Dell Inspiron 14z Memory module Replacement
Neye ihtiyacın var
  1. Dell Inspiron 14z Memory module Replacement, Memory module: adım 1, 3 resimden 1. Dell Inspiron 14z Memory module Replacement, Memory module: adım 1, 3 resimden 2. Dell Inspiron 14z Memory module Replacement, Memory module: adım 1, 3 resimden 3.
    • Here is a Dell Inspiron 14z N411z that is going to get a new memory module.
    • On the back side is only one cover for the hard drive as well as the memory module.
    • Remove the Phillips screw on the bottom right corner of the cover.
  2. Dell Inspiron 14z Memory module Replacement: adım 2, 3 resimden 1. Dell Inspiron 14z Memory module Replacement: adım 2, 3 resimden 2. Dell Inspiron 14z Memory module Replacement: adım 2, 3 resimden 3.
    • Use a plastic opening tool to unsnap the cover from the back case.
    • Move the tool gently along the corner of the cover.
    • The screw that holds the cover on, has a spring clip that keeps the screw attached to the cover. during removal of the screw, this clip might come of.
  3. Dell Inspiron 14z Memory module Replacement: adım 3, 3 resimden 1. Dell Inspiron 14z Memory module Replacement: adım 3, 3 resimden 2. Dell Inspiron 14z Memory module Replacement: adım 3, 3 resimden 3.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the memory module pops up
    • With the securing clips spread, the memory module will pop up.
    • Remove the memory module and replace as needed.
Sonuç
Bir başkası bu kılavuzu tamamladı.
oldturkey03
781.527 İtibar
119 adet Kılavuz yazıldı
Ekip
Global Fixers Global Fixers üyesi
Community
32 Üyeler
531 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 1,790
