Ana içeriğe geç
Dell Inspiron 14z Memory module Replacement
Neye ihtiyacın var
  1. Dell Inspiron 14z Memory module Replacement, Memory module: adım 1, 3 resimden 1. Dell Inspiron 14z Memory module Replacement, Memory module: adım 1, 3 resimden 2. Dell Inspiron 14z Memory module Replacement, Memory module: adım 1, 3 resimden 3.
    • Here is a Dell Inspiron 14z N411z that is going to get a new memory module.
    • On the back side is only one cover for the hard drive as well as the memory module.
    • Remove the Phillips screw on the bottom right corner of the cover.
  2. Dell Inspiron 14z Memory module Replacement: adım 2, 3 resimden 1. Dell Inspiron 14z Memory module Replacement: adım 2, 3 resimden 2. Dell Inspiron 14z Memory module Replacement: adım 2, 3 resimden 3.
    • Use a plastic opening tool to unsnap the cover from the back case.
    • Move the tool gently along the corner of the cover.
    • The screw that holds the cover on, has a spring clip that keeps the screw attached to the cover. during removal of the screw, this clip might come of.
  3. Dell Inspiron 14z Memory module Replacement: adım 3, 3 resimden 1. Dell Inspiron 14z Memory module Replacement: adım 3, 3 resimden 2. Dell Inspiron 14z Memory module Replacement: adım 3, 3 resimden 3.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the memory module pops up
    • With the securing clips spread, the memory module will pop up.
    • Remove the memory module and replace as needed.
Sonuç
Bir başkası bu kılavuzu tamamladı.
oldturkey03
817.626 İtibar
119 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 1,814
