Ana içeriğe geç
Dell Inspiron 14z-5423 Keyboard Replacement
Neye ihtiyacın var
  1. Dell Inspiron 14z-5423 Keyboard Replacement, RAM: adım 1, 2 resimden 1. Dell Inspiron 14z-5423 Keyboard Replacement, RAM: adım 1, 2 resimden 2.
    • Close the display and turn over the computer.
    • Make sure your device is powered down and unplugged before beginning the replacement.
  2. Dell Inspiron 14z-5423 Keyboard Replacement: adım 2, 1 resimden 1.
    • Use a J0 bit tipped screwdriver to unscrew the one 6 mm Phillips screw on the RAM cover.
  3. Dell Inspiron 14z-5423 Keyboard Replacement: adım 3, 2 resimden 1. Dell Inspiron 14z-5423 Keyboard Replacement: adım 3, 2 resimden 2.
    • Lightly lift the RAM cover up and at an angle, away from the computer.
  4. Dell Inspiron 14z-5423 Keyboard Replacement: adım 4, 2 resimden 1. Dell Inspiron 14z-5423 Keyboard Replacement: adım 4, 2 resimden 2.
    • Use your fingers to carefully pull the securing clips on the RAM away from each other.
    • The RAM should pop up when the clips are released.
  5. Dell Inspiron 14z-5423 Keyboard Replacement: adım 5, 2 resimden 1. Dell Inspiron 14z-5423 Keyboard Replacement: adım 5, 2 resimden 2.
    • Remove the popped up RAM by pulling it away from the connection.
    • If it does not pop up pry it out in a steady and straight direction.
  6. Dell Inspiron 14z-5423 Keyboard Replacement, Keyboard: adım 6, 3 resimden 1. Dell Inspiron 14z-5423 Keyboard Replacement, Keyboard: adım 6, 3 resimden 2. Dell Inspiron 14z-5423 Keyboard Replacement, Keyboard: adım 6, 3 resimden 3.
    • Lift the plastic yellow flap on the system board.
    • Use the J0 Bit screwdriver to remove the one 6 mm Phillips screw in center of the system board that is connected to the keyboard.
  7. Dell Inspiron 14z-5423 Keyboard Replacement: adım 7, 1 resimden 1.
    • Flip over the computer and open the display.
  8. Dell Inspiron 14z-5423 Keyboard Replacement: adım 8, 2 resimden 1. Dell Inspiron 14z-5423 Keyboard Replacement: adım 8, 2 resimden 2.
    • Insert a spudger next to the plastic indents located at the top of the keyboard and gently pry to release the securing clips.
    • Lift the keyboard off of the computer.
    • Be careful not to tear the ribbon that attaches the back of the keyboard to the computer when lifting it.
  9. Dell Inspiron 14z-5423 Keyboard Replacement: adım 9, 2 resimden 1. Dell Inspiron 14z-5423 Keyboard Replacement: adım 9, 2 resimden 2.
    • Flip the keyboard over onto the palm-rest assembly.
  10. Dell Inspiron 14z-5423 Keyboard Replacement: adım 10, 3 resimden 1. Dell Inspiron 14z-5423 Keyboard Replacement: adım 10, 3 resimden 2. Dell Inspiron 14z-5423 Keyboard Replacement: adım 10, 3 resimden 3.
    • Flip the little black securing bar near the base of the ribbon with a spudger to release the ribbon from the computer.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Marisol
623 İtibar
4 adet Kılavuz yazıldı
Ekip
CSU Fullerton, Team 2-2, Bruce Fall 2016 CSU Fullerton, Team 2-2, Bruce Fall 2016 üyesi
CSUF-BRUCE-F16S2G2
5 Üyeler
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 18
Her zaman: 1,497
