Ana içeriğe geç
Dell Inspiron 14z-5423 Motherboard Replacement
Neye ihtiyacın var
  1. Dell Inspiron 14z-5423 Motherboard Replacement, RAM: adım 1, 2 resimden 1. Dell Inspiron 14z-5423 Motherboard Replacement, RAM: adım 1, 2 resimden 2.
    • Close the display and turn over the computer.
    • Make sure your device is powered down and unplugged before beginning the replacement.
  2. Dell Inspiron 14z-5423 Motherboard Replacement: adım 2, 1 resimden 1.
    • Use a J0 bit tipped screwdriver to unscrew the one 6 mm Phillips screw on the RAM cover.
  3. Dell Inspiron 14z-5423 Motherboard Replacement: adım 3, 2 resimden 1. Dell Inspiron 14z-5423 Motherboard Replacement: adım 3, 2 resimden 2.
    • Lightly lift the RAM cover up and at an angle, away from the computer.
  4. Dell Inspiron 14z-5423 Motherboard Replacement: adım 4, 2 resimden 1. Dell Inspiron 14z-5423 Motherboard Replacement: adım 4, 2 resimden 2.
    • Use your fingers to carefully pull the securing clips on the RAM away from each other.
    • The RAM should pop up when the clips are released.
  5. Dell Inspiron 14z-5423 Motherboard Replacement: adım 5, 2 resimden 1. Dell Inspiron 14z-5423 Motherboard Replacement: adım 5, 2 resimden 2.
    • Remove the popped up RAM by pulling it away from the connection.
    • If it does not pop up pry it out in a steady and straight direction.
  6. Dell Inspiron 14z-5423 Motherboard Replacement, Optical Drive: adım 6, 2 resimden 1. Dell Inspiron 14z-5423 Motherboard Replacement, Optical Drive: adım 6, 2 resimden 2.
    • Slide the CD/DVD drive on the side of the laptop out using your fingers.
    • Using a J0 bit screwdriver, unscrew the one 2 mm Phillips screw.
    • You only need to unscrew this screw if you are using this as a prerequisite guide.
  7. Dell Inspiron 14z-5423 Motherboard Replacement, Keyboard: adım 7, 3 resimden 1. Dell Inspiron 14z-5423 Motherboard Replacement, Keyboard: adım 7, 3 resimden 2. Dell Inspiron 14z-5423 Motherboard Replacement, Keyboard: adım 7, 3 resimden 3.
    • Lift the plastic yellow flap on the system board.
    • Use the J0 Bit screwdriver to remove the one 6 mm Phillips screw in center of the system board that is connected to the keyboard.
  8. Dell Inspiron 14z-5423 Motherboard Replacement: adım 8, 1 resimden 1.
    • Flip over the computer and open the display.
  9. Dell Inspiron 14z-5423 Motherboard Replacement: adım 9, 2 resimden 1. Dell Inspiron 14z-5423 Motherboard Replacement: adım 9, 2 resimden 2.
    • Insert a spudger next to the plastic indents located at the top of the keyboard and gently pry to release the securing clips.
    • Lift the keyboard off of the computer.
    • Be careful not to tear the ribbon that attaches the back of the keyboard to the computer when lifting it.
  10. Dell Inspiron 14z-5423 Motherboard Replacement: adım 10, 2 resimden 1. Dell Inspiron 14z-5423 Motherboard Replacement: adım 10, 2 resimden 2.
    • Flip the keyboard over onto the palm-rest assembly.
  11. Dell Inspiron 14z-5423 Motherboard Replacement: adım 11, 3 resimden 1. Dell Inspiron 14z-5423 Motherboard Replacement: adım 11, 3 resimden 2. Dell Inspiron 14z-5423 Motherboard Replacement: adım 11, 3 resimden 3.
    • Flip the little black securing bar near the base of the ribbon with a spudger to release the ribbon from the computer.
  12. Dell Inspiron 14z-5423 Motherboard Replacement, Palm Rest Assembly: adım 12, 1 resimden 1.
  13. Dell Inspiron 14z-5423 Motherboard Replacement: adım 13, 3 resimden 1. Dell Inspiron 14z-5423 Motherboard Replacement: adım 13, 3 resimden 2. Dell Inspiron 14z-5423 Motherboard Replacement: adım 13, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Remove all 7 rubber screw caps with tweezers.
    • Use a J0 Bit tipped screwdriver unscrew the seven 6 mm Phillips screws on the back casing of the laptop.
  14. Dell Inspiron 14z-5423 Motherboard Replacement: adım 14, 2 resimden 1. Dell Inspiron 14z-5423 Motherboard Replacement: adım 14, 2 resimden 2.
    • Flip the computer over and open the display.
    • Pull on the blue tabs to disconnect the palm rest assembly from the computer.
  15. Dell Inspiron 14z-5423 Motherboard Replacement: adım 15, 1 resimden 1.
    • Use J0 Bit screwdriver to remove all four 6 mm Phillips screws.
  16. Dell Inspiron 14z-5423 Motherboard Replacement: adım 16, 3 resimden 1. Dell Inspiron 14z-5423 Motherboard Replacement: adım 16, 3 resimden 2. Dell Inspiron 14z-5423 Motherboard Replacement: adım 16, 3 resimden 3.
    • Gently wedge the nylon spudger underneath the palm-rest assembly to release the latches.
    • Continue this process on all sides of the computer edges until the assembly pulls off.
    • Remove the palm rest assembly.
    • If you have difficulty lifting up the assembly, you might not have taken out all 7 screws on the bottom of the computer.
  17. Dell Inspiron 14z-5423 Motherboard Replacement, Battery: adım 17, 2 resimden 1. Dell Inspiron 14z-5423 Motherboard Replacement, Battery: adım 17, 2 resimden 2.
    • Use a J0 Bit screwdriver to remove the two 6 mm Phillips screws securing the battery located near the bottom of the laptop.
  18. Dell Inspiron 14z-5423 Motherboard Replacement: adım 18, 3 resimden 1. Dell Inspiron 14z-5423 Motherboard Replacement: adım 18, 3 resimden 2. Dell Inspiron 14z-5423 Motherboard Replacement: adım 18, 3 resimden 3.
    • Lift the tiny black tab and pull the battery out at a slight angle.
  19. Dell Inspiron 14z-5423 Motherboard Replacement, Hard Drive: adım 19, 2 resimden 1. Dell Inspiron 14z-5423 Motherboard Replacement, Hard Drive: adım 19, 2 resimden 2.
    • Lift up the bottom of the hard drive which is located at the bottom of the laptop.
    • Gently pull the drive out at an angle using your fingers.
  20. Dell Inspiron 14z-5423 Motherboard Replacement: adım 20, 1 resimden 1.
    • Using a J0 bit tipped screwdriver, remove the four 3 mm black screws on both sides of the hard drive bracket.
  21. Dell Inspiron 14z-5423 Motherboard Replacement: adım 21, 1 resimden 1.
    • Slide the hard drive out of the bracket.
  22. Dell Inspiron 14z-5423 Motherboard Replacement, Wireless Mini Card: adım 22, 2 resimden 1. Dell Inspiron 14z-5423 Motherboard Replacement, Wireless Mini Card: adım 22, 2 resimden 2.
    • Locate the wireless mini card at the top of the laptop.
    • It is next to the place where the optics drive used to be.
  23. Dell Inspiron 14z-5423 Motherboard Replacement: adım 23, 1 resimden 1.
    • Using a J0 tipped screwdriver, remove the 4 mm Phillips head screw.
  24. Dell Inspiron 14z-5423 Motherboard Replacement: adım 24, 2 resimden 1. Dell Inspiron 14z-5423 Motherboard Replacement: adım 24, 2 resimden 2.
    • Gently, unlatch the black and white wires from the wireless mini card.
  25. Dell Inspiron 14z-5423 Motherboard Replacement: adım 25, 1 resimden 1.
    • At an angle, slide out the wireless mini card.
  26. Dell Inspiron 14z-5423 Motherboard Replacement, Motherboard: adım 26, 2 resimden 1. Dell Inspiron 14z-5423 Motherboard Replacement, Motherboard: adım 26, 2 resimden 2.
    • Gently pull the the blue ribbon upwards to disconnect the computer from the motherboard.
  27. Dell Inspiron 14z-5423 Motherboard Replacement: adım 27, 2 resimden 1. Dell Inspiron 14z-5423 Motherboard Replacement: adım 27, 2 resimden 2.
    • Using a plastic opening tool, gently detach the coin cell battery from the foam glue.
    • The coin cell battery is underneath the optical drive.
  28. Dell Inspiron 14z-5423 Motherboard Replacement: adım 28, 2 resimden 1. Dell Inspiron 14z-5423 Motherboard Replacement: adım 28, 2 resimden 2.
    • Using a J0 tipped screwdriver remove the 6 mm Phillips head screw located at the center of the laptop on the motherboard.
  29. Dell Inspiron 14z-5423 Motherboard Replacement: adım 29, 1 resimden 1.
    • Remove motherboard at an upward angle.
    • The coin cell battery and fan will be removed with the motherboard.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Marisol
626 İtibar
4 adet Kılavuz yazıldı
Ekip
CSU Fullerton, Team 2-2, Bruce Fall 2016 CSU Fullerton, Team 2-2, Bruce Fall 2016 üyesi
CSUF-BRUCE-F16S2G2
5 Üyeler
11 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 20
Her zaman: 2,628
