Ana içeriğe geç
Dell Inspiron 15 3541 Keyboard Replacement
Neye ihtiyacın var
  1. Dell Inspiron 15 3541 Keyboard Replacement, Battery: adım 1, 2 resimden 1. Dell Inspiron 15 3541 Keyboard Replacement, Battery: adım 1, 2 resimden 2.
    • Make sure your laptop is powered off completely and is not connected to the charger.
    • Close the laptop and place it so that the back of the screen is lying flat on your work surface.
    • Slide both of the battery-release latches towards the outer edges of the laptop to unlock the battery flap.
  2. Dell Inspiron 15 3541 Keyboard Replacement: adım 2, 1 resimden 1.
    • Lift the battery at an angle using your fingertips and remove it from the laptop.
    • Press and hold the power button for 5 seconds. This ensures that any remaining power will drain out of the computer.
  3. Dell Inspiron 15 3541 Keyboard Replacement, Keyboard: adım 3, 2 resimden 1. Dell Inspiron 15 3541 Keyboard Replacement, Keyboard: adım 3, 2 resimden 2.
    • Open the laptop and fully extend the screen.
    • Using the nylon spudger, pry the keyboard off the laptop body.
    • Using your hands, remove the keyboard from the body and place it facedown on the track pad. There will be a cord connecting the laptop and the keyboard: keep this cord intact.
  4. Dell Inspiron 15 3541 Keyboard Replacement: adım 4, 2 resimden 1. Dell Inspiron 15 3541 Keyboard Replacement: adım 4, 2 resimden 2.
    • Unhook the connector and you can now remove the keyboard from the laptop
    • If your version of this laptop has a backlit keyboard, there will be two connectors; the one highlighted orange will also have to be removed.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Allison
571 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-8, Landers Spring 2016 UMass Dartmouth, Team 5-8, Landers Spring 2016 üyesi
UMASSD-LANDERS-S16S5G8
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 16
Son 30 gün: 24
Her zaman: 3,521
