Ana içeriğe geç
Dell Inspiron 15 3565 Hard Drive Replacement
Neye ihtiyacın var
  1. Dell Inspiron 15 3565 Hard Drive Replacement, Disconnect the Hard Drive Cable: adım 1, 1 resimden 1.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
    • Open the latch and disconnect the hard-drive cable from the system board.
  2. Dell Inspiron 15 3565 Hard Drive Replacement, Remove the Screws: adım 2, 1 resimden 1.
    • Remove the four screws (M2x3) that secure the hard-drive assembly to the palm-rest assembly.
  3. Dell Inspiron 15 3565 Hard Drive Replacement, Lifting the Hard-Drive Assembly: adım 3, 1 resimden 1.
    • Lift the hard-drive assembly off the palm-rest assembly.
  4. Dell Inspiron 15 3565 Hard Drive Replacement, Disconnecting the Interposer: adım 4, 1 resimden 1.
    • Disconnect the interposer from the hard-drive assembly.
  5. Dell Inspiron 15 3565 Hard Drive Replacement, Remove the Screws: adım 5, 1 resimden 1.
    • Remove the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
  6. Dell Inspiron 15 3565 Hard Drive Replacement, Lifting the Hard Drive: adım 6, 1 resimden 1.
    • Lift the hard drive off the hard-drive bracket.
  7. Dell Inspiron 15 3565 Hard Drive Replacement, Align the Screw Holes: adım 7, 1 resimden 1.
    • Align the screw holes on the hard-drive bracket with the screw holes on the NEW hard drive.
  8. Dell Inspiron 15 3565 Hard Drive Replacement, Replace the Screws: adım 8, 1 resimden 1.
    • Replace the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
  9. Dell Inspiron 15 3565 Hard Drive Replacement, Connect the Interposer: adım 9, 1 resimden 1.
    • Connect the interposer to the hard drive.
  10. Dell Inspiron 15 3565 Hard Drive Replacement, Placing the Hard Drive Assembly: adım 10, 2 resimden 1. Dell Inspiron 15 3565 Hard Drive Replacement, Placing the Hard Drive Assembly: adım 10, 2 resimden 2.
    • Place the hard-drive assembly in the palm-rest assembly and align the screw holes on the hard-drive assembly with the screw holes on the palm-rest assembly.
  11. Dell Inspiron 15 3565 Hard Drive Replacement, Replace the Screws: adım 11, 1 resimden 1.
    • Replace the four screws (M2x3) that secure the hard-drive assembly to the palm-rest assembly.
  12. Dell Inspiron 15 3565 Hard Drive Replacement, Sliding the Hard Drive Cable: adım 12, 1 resimden 1.
    • Slide the hard-drive cable into its connector on the system board and close the latch to secure the cable.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Terrence15
79.585 İtibar
441 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
43 Üyeler
1.985 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 14
Her zaman: 1,755
