Giriş
In this guide, we will be showing you how to remove and replace the Memory Module.
Using your fingertips, carefully spread apart the securing clips on each end of the memory-module slot until the memory module pops up.
Slide and remove the memory module from the memory-module slot.
Align the notch on the memory module with the tab on the memory-module slot and slide it firmly into the slot at an angle.
Press the memory module down until it clicks into place.
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
What Laptop is this for? I guess the disassembly must be somewhere else.
