Giriş
In this guide, we will be showing you how to remove and replace the Hard Drive.
Neye ihtiyacın var
Open the latch and disconnect the hard-drive cable from the system board.
Remove the four screws (M2x3) that secure the hard-drive assembly to the palm-rest assembly.
Lift the hard-drive assembly off the palm-rest assembly.
Remove the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
Align the screw holes on the hard-drive bracket with the screw holes on the NEW hard drive.
Replace the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
Place the hard-drive assembly in the palm-rest assembly and align the screw holes on the hard-drive assembly with the screw holes on the palm-rest assembly.
Replace the four screws (M2x3) that secure the hard-drive assembly to the palm-rest assembly.
Slide the hard-drive cable into its connector on the system board and close the latch to secure the cable.
3 farklı kişi bu kılavuzu tamamladı.
5 Yorum
The steps that need to be PRIOR to this guide are to remove the keyboard first, disconnect the keyboard cable, remove the 5 screws under the keyboard attaching the plastic to the motherboard. Then turn over the laptop, remove some 12 screws or so, remove the battery, remove the DVD drive, then separate the bottom case from the rest of the laptop carefully.
This guide is totally incomplete. It doesn't show how to access the drive in the first place. This guide should be taken down.
