Ana içeriğe geç
Dell Inspiron 15 3568 Hard Drive Replacement
Neye ihtiyacın var
  1. Dell Inspiron 15 3568 Hard Drive Replacement, Remove the Screws: adım 1, 1 resimden 1.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
    • Remove the screws that secure the hard-drive assembly to the computer base.
  2. Dell Inspiron 15 3568 Hard Drive Replacement, Lifting the Latch: adım 2, 2 resimden 1. Dell Inspiron 15 3568 Hard Drive Replacement, Lifting the Latch: adım 2, 2 resimden 2.
    • Lift the latch and disconnect the hard-drive cable from the system board.
  3. Dell Inspiron 15 3568 Hard Drive Replacement, Lifting the Hard-Drive Assembly: adım 3, 1 resimden 1.
    • Lift the hard-drive assembly off the computer base.
  4. Dell Inspiron 15 3568 Hard Drive Replacement, Disconnecting the Interposer: adım 4, 1 resimden 1.
    • Disconnect the interposer from the hard drive.
  5. Dell Inspiron 15 3568 Hard Drive Replacement, Remove the Screws: adım 5, 1 resimden 1.
    • Remove the screws that secure the hard-drive bracket to the hard drive and lift the hard-drive bracket off the hard drive.
  6. Dell Inspiron 15 3568 Hard Drive Replacement, Placing the Hard-Drive Bracket: adım 6, 1 resimden 1.
    • Place the hard-drive bracket over the NEW hard drive and align the screw holes on the hard-drive bracket with the screw holes on the hard drive.
  7. Dell Inspiron 15 3568 Hard Drive Replacement, Replace the Screws: adım 7, 1 resimden 1.
    • Replace the screws that secure the hard-drive bracket to the hard drive.
  8. Dell Inspiron 15 3568 Hard Drive Replacement, Sliding the Hard-Drive Assembly: adım 8, 1 resimden 1.
    • Slide the hard-drive assembly in the computer base and align the screw holes on the hard-drive assembly with the screw holes on the computer base.
  9. Dell Inspiron 15 3568 Hard Drive Replacement, Slide the Hard-Drive Cable: adım 9, 2 resimden 1. Dell Inspiron 15 3568 Hard Drive Replacement, Slide the Hard-Drive Cable: adım 9, 2 resimden 2.
    • Slide the hard-drive cable into its connector and close the latch to secure the cable.
  10. Dell Inspiron 15 3568 Hard Drive Replacement, Replace the Screws: adım 10, 1 resimden 1.
    • Replace the screws that secure the hard-drive assembly to the computer base.
Bitiş Çizgisi
Terrence15
79.585 İtibar
441 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
43 Üyeler
1.985 adet Kılavuz yazıldı
1Rehber Yorum
SSD slot is available or not ? thank you
mbu Shrestha - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 16
Her zaman: 820
