Ana içeriğe geç
Dell Inspiron 15 5565 IO Board Replacement
Neye ihtiyacın var
  1. Dell Inspiron 15 5565 IO Board Replacement, Optical Drive: adım 1, 1 resimden 1.
    • Remove the 4 mm screw that secures the optical drive bracket to the optical drive using a Phillips #00 screwdriver.
  2. Dell Inspiron 15 5565 IO Board Replacement: adım 2, 3 resimden 1. Dell Inspiron 15 5565 IO Board Replacement: adım 2, 3 resimden 2. Dell Inspiron 15 5565 IO Board Replacement: adım 2, 3 resimden 3.
    • Eject the optical drive by pressing the eject button.
    • Push out the optical drive bracket using the iFixit opening tool.
  3. Dell Inspiron 15 5565 IO Board Replacement, Back Cover: adım 3, 2 resimden 1. Dell Inspiron 15 5565 IO Board Replacement, Back Cover: adım 3, 2 resimden 2.
    • Remove 13 8 mm screws from the bottom of the device using a Phillips #00 screwdriver.
    • Remove the single 4 mm screw from the bottom of the device using a Phillips #00 screwdriver.
    • Remove the three 4 mm screws from the optical drive slot using a Phillips #00 screwdriver.
  4. Dell Inspiron 15 5565 IO Board Replacement: adım 4, 2 resimden 1. Dell Inspiron 15 5565 IO Board Replacement: adım 4, 2 resimden 2.
    • Remove the back cover from the laptop.
  5. Dell Inspiron 15 5565 IO Board Replacement, IO Board: adım 5, 3 resimden 1. Dell Inspiron 15 5565 IO Board Replacement, IO Board: adım 5, 3 resimden 2. Dell Inspiron 15 5565 IO Board Replacement, IO Board: adım 5, 3 resimden 3.
    • Lift up the cover to pull out the cable.
  6. Dell Inspiron 15 5565 IO Board Replacement: adım 6, 3 resimden 1. Dell Inspiron 15 5565 IO Board Replacement: adım 6, 3 resimden 2. Dell Inspiron 15 5565 IO Board Replacement: adım 6, 3 resimden 3.
    • Remove the single 5 mm screw from the main part of the IO board using a Phillips #00 screwdriver.
    • Remove the IO board from the device.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 5
Her zaman: 82
