Giriş
In this guide, we will be showing you how to remove and replace the Memory Modules.
Use your fingertips to carefully spread apart the securing-clips on each end of the memory-module slot until the memory module pops up.
Align the notch on the NEW memory module with the tab on the memory-module slot and slide it firmly into the slot at an angle.
Press the memory module down until it clicks into place.
Bir başkası bu kılavuzu tamamladı.
