Giriş
In this guide, we will be showing you how to remove and replace the Display Assembly.
Neye ihtiyacın var
Turn the computer over and open the display to 180-degree angle.
Place the computer on a flat surface with the display facing down.
Remove the two screws (M2.5x7) that secure the display assembly to the palm rest and keyboard assembly.
Remove the antenna cables from the routing guide on the palm rest and keyboard assembly.
Lift the display assembly off the palm rest and keyboard assembly.
With the display facing down, align the screw holes on the display hinges with the screw holes on the palm rest and keyboard assembly.
Replace the two screws (M2.5x7) that secure the display assembly to the palm rest and keyboard assembly.
Bir başkası bu kılavuzu tamamladı.
