Ana içeriğe geç
Dell Inspiron 15 5584 RAM Replacement
Neye ihtiyacın var
    1. Dell Inspiron 15 5584 RAM Replacement, Bottom Cover: adım 1, 1 resimden 1.
      • Make sure to turn off and unplug your laptop before starting.
      • Turn over the laptop so that the bottom is facing upwards, and the Inspiron logo is upside-down.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Inspiron 15 5584 RAM Replacement: adım 2, 3 resimden 1. Dell Inspiron 15 5584 RAM Replacement: adım 2, 3 resimden 2. Dell Inspiron 15 5584 RAM Replacement: adım 2, 3 resimden 3.
      • Remove the seven 7 mm screws from the bottom using a Phillips #0 screwdriver.
      • Loosen the two captive back corner screws using a Phillips #0 screwdriver.
      • The two corner screws are not removable. A clicking sounds indicates that the screw is fully loosened.
      FixBot'a Sor
      Yorum Ekle
    3. Dell Inspiron 15 5584 RAM Replacement: adım 3, 2 resimden 1. Dell Inspiron 15 5584 RAM Replacement: adım 3, 2 resimden 2.
      • Slide an iFixit opening tool underneath the right side USB port and the keyboard.
      • Gently trace the iFixit opening tool along the entire outer rim of the laptop, carefully applying an upwards pressure.
      • Be careful not to force open the plate or push too much off without loosening the other sides. This can cause the bottom cover to crack.
      FixBot'a Sor
      Yorum Ekle
    4. Dell Inspiron 15 5584 RAM Replacement: adım 4, 2 resimden 1. Dell Inspiron 15 5584 RAM Replacement: adım 4, 2 resimden 2.
      • Gently pry off the bottom cover from the laptop.
      • Use the iFixit opening tool to loosen any spots you may have missed from Step 3.
      FixBot'a Sor
      Yorum Ekle
    1. Dell Inspiron 15 5584 RAM Replacement, Battery: adım 5, 2 resimden 1. Dell Inspiron 15 5584 RAM Replacement, Battery: adım 5, 2 resimden 2.
      • Remove the four 3.5 mm screws holding the battery down with a JIS #0 screwdriver.
      • Official iFixit PH000-PH1 Phillips screwdrivers and bits are designed to be compatible with JIS screws, so they are safe to use.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Inspiron 15 5584 RAM Replacement: adım 6, 3 resimden 1. Dell Inspiron 15 5584 RAM Replacement: adım 6, 3 resimden 2. Dell Inspiron 15 5584 RAM Replacement: adım 6, 3 resimden 3.
      • Detach the motherboard connector tab from the top left of the battery.
      • Remove the battery from the device.
      • Be sure to carefully wiggle the connector out from the battery socket. Ripping it out too forcefully could damage the socket.
      FixBot'a Sor
      Yorum Ekle
    1. Dell Inspiron 15 5584 RAM Replacement, RAM: adım 7, 1 resimden 1.
      • Firmly apply pressure on the two latches to the right and left of the RAM stick.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Inspiron 15 5584 RAM Replacement: adım 8, 1 resimden 1.
      • At an angle, gently pull the RAM stick out of the socket.
      • Remove the RAM stick from the motherboard socket.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Sam Vorn
1.015 İtibar
9 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-1, Mellen Spring 2022 UMass Dartmouth, Team 1-1, Mellen Spring 2022 üyesi
UMASSD-MELLEN-S22S1G1
3 Üyeler
68 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 26
Her zaman: 765
