Ana içeriğe geç
Dell Inspiron 15 7560 Fan Replacement
Neye ihtiyacın var
  1. Dell Inspiron 15 7560 Fan Replacement, Fan: adım 1, 1 resimden 1.
    • Power off the laptop.
    • Place the laptop with the bottom facing upwards.
    • Remove eight 5 mm screws from the bottom of the laptop.
    • Loosen the three captive screws.
    • Use an iFixit opening tool to pry the bottom cover away from the laptop.
  2. Dell Inspiron 15 7560 Fan Replacement: adım 2, 1 resimden 1.
    • Remove the two screws from the fan.
  3. Dell Inspiron 15 7560 Fan Replacement: adım 3, 2 resimden 1. Dell Inspiron 15 7560 Fan Replacement: adım 3, 2 resimden 2.
    • Remove the black insulating tape from the fan connector.
    • Pinch the sides of the white fan connector with your thumb and index fingernail and pull it out of its socket.
    • Remove the fan from the laptop.
    • Save the insulating tape for reinstallation.
  4. Dell Inspiron 15 7560 Fan Replacement: adım 4, 2 resimden 1. Dell Inspiron 15 7560 Fan Replacement: adım 4, 2 resimden 2.
    • Place the new fan in the laptop.
    • Plug the cable connector into its socket on the motherboard.
    • Replace the two screws around the fan.
  5. Dell Inspiron 15 7560 Fan Replacement: adım 5, 1 resimden 1.
    • Before replacing the bottom cover, start the computer to check if the cooling fan is installed successfully.
  6. Dell Inspiron 15 7560 Fan Replacement: adım 6, 1 resimden 1.
    • Power down the computer.
    • Reassemble the bottom cover.
Bitiş Çizgisi
Kristen Gismondi
82.723 İtibar
202 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
136 Üyeler
17.439 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 16
Son 30 gün: 33
Her zaman: 695
