Ana içeriğe geç
Dell Inspiron 15 7560 Hard Drive Replacement
Neye ihtiyacın var
  1. Dell Inspiron 15 7560 Hard Drive Replacement, Remove the Screws: adım 1, 1 resimden 1.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
    • Remove the four screws (M2x3) that secure the hard-drive assembly to the palm rest and keyboard assembly.
  2. Dell Inspiron 15 7560 Hard Drive Replacement, Lifting the Hard Drive: adım 2, 1 resimden 1.
    • Lift the hard-drive assembly off the palm rest and keyboard assembly.
  3. Dell Inspiron 15 7560 Hard Drive Replacement, Disconnect the Interposer: adım 3, 1 resimden 1.
    • Disconnect the interposer from the hard-drive assembly.
  4. Dell Inspiron 15 7560 Hard Drive Replacement, Remove the Screws: adım 4, 1 resimden 1.
    • Remove the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
  5. Dell Inspiron 15 7560 Hard Drive Replacement, Lifting the Hard Drive Bracket: adım 5, 1 resimden 1.
    • Lift the hard-drive bracket off the hard drive.
  6. Dell Inspiron 15 7560 Hard Drive Replacement, Align the Screw Holes: adım 6, 1 resimden 1.
    • Align the screw holes on the hard-drive bracket with the screw holes on the NEW hard drive.
  7. Dell Inspiron 15 7560 Hard Drive Replacement, Replace the Screws: adım 7, 1 resimden 1.
    • Replace the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
  8. Dell Inspiron 15 7560 Hard Drive Replacement, Connect the Interposer: adım 8, 1 resimden 1.
    • Connect the interposer to the hard-drive assembly.
  9. Dell Inspiron 15 7560 Hard Drive Replacement, Align the Screw Holes: adım 9, 1 resimden 1.
    • Align the screw holes on the hard-drive assembly with the screw holes on the palm rest and keyboard assembly.
  10. Dell Inspiron 15 7560 Hard Drive Replacement, Replace the Screws: adım 10, 1 resimden 1.
    • Replace the four screws (M2x3) that secure the hard-drive assembly to the palm rest and keyboard assembly.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Terrence15
79.555 İtibar
441 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
43 Üyeler
1.985 adet Kılavuz yazıldı
Bir Yorum
is the hard drive where the os is installed or in the m.2 drive and can i use a wd blue 512gb 3d nand ssd
Ethan Abraham - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 7
Son 30 gün: 18
Her zaman: 1,154
