Ana içeriğe geç
Dell Inspiron 15 7579 Back Panel Replacement
Neye ihtiyacın var
  1. Dell Inspiron 15 7579 Back Panel Replacement, Back Panel: adım 1, 1 resimden 1.
    • Remove the ten 7.9 mm screws with the Phillips PH0 screwdriver.
  2. Dell Inspiron 15 7579 Back Panel Replacement: adım 2, 2 resimden 1. Dell Inspiron 15 7579 Back Panel Replacement: adım 2, 2 resimden 2.
    • Insert metal spudger into a gap in between the back panel and the back of the screen.
    • Pry off the back panel using the metal spudger as a lever, and remove the back panel by lifting the rest off by hand.
Sonuç
Inaki Madrigal
760 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S24-G9, Maness Spring 2018 Cal Poly, Team S24-G9, Maness Spring 2018 üyesi
CPSU-MANESS-S18S24G9
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 14
Her zaman: 1,125
