Ana içeriğe geç
Dell Inspiron 15 7579 Display Replacement
Neye ihtiyacın var
  1. Dell Inspiron 15 7579 Display Replacement, Back Panel: adım 1, 1 resimden 1.
    • Remove the ten 7.9 mm screws with the Phillips PH0 screwdriver.
  2. Dell Inspiron 15 7579 Display Replacement: adım 2, 2 resimden 1. Dell Inspiron 15 7579 Display Replacement: adım 2, 2 resimden 2.
    • Insert metal spudger into a gap in between the back panel and the back of the screen.
    • Pry off the back panel using the metal spudger as a lever, and remove the back panel by lifting the rest off by hand.
  3. Dell Inspiron 15 7579 Display Replacement, Fan: adım 3, 2 resimden 1. Dell Inspiron 15 7579 Display Replacement, Fan: adım 3, 2 resimden 2.
    • Remove the two 7.9 mm screws from the fan with a Phillips #0 screwdriver.
  4. Dell Inspiron 15 7579 Display Replacement: adım 4, 2 resimden 1. Dell Inspiron 15 7579 Display Replacement: adım 4, 2 resimden 2.
    • Unplug the wires from the port.
    • Be sure to pull from the plastic connector, not the wires.
  5. Dell Inspiron 15 7579 Display Replacement: adım 5, 1 resimden 1.
    • Carefully lift the fan out of the computer.
  6. Dell Inspiron 15 7579 Display Replacement, SSD M.2 Drive: adım 6, 1 resimden 1.
    • Remove the single 3.6 mm screw holding the left side of the M.2 SSD card with a Phillips PH0 screwdriver.
  7. Dell Inspiron 15 7579 Display Replacement: adım 7, 1 resimden 1.
    • Gently pull out the SSD card at the angle it is relaxed in to remove it. It is easiest to do this by hand.
    • Be gentle when pulling the SSD card out. It should take little effort to get it to slide out properly.
  8. Dell Inspiron 15 7579 Display Replacement, Motherboard: adım 8, 2 resimden 1. Dell Inspiron 15 7579 Display Replacement, Motherboard: adım 8, 2 resimden 2.
    • Remove the six 2.1 mm screws with the Phillips #0 screwdriver.
  9. Dell Inspiron 15 7579 Display Replacement: adım 9, 2 resimden 1. Dell Inspiron 15 7579 Display Replacement: adım 9, 2 resimden 2.
    • Unplug the eight ribbon cables connected to the motherboard.
  10. Dell Inspiron 15 7579 Display Replacement: adım 10, 1 resimden 1.
    • Lift the motherboard up from the side opposite of the external ports and remove it from the laptop.
  11. Dell Inspiron 15 7579 Display Replacement, Display: adım 11, 2 resimden 1. Dell Inspiron 15 7579 Display Replacement, Display: adım 11, 2 resimden 2.
    • Remove the screw that holds the Wi-Fi card in place with a Phillips #0 screwdriver.
    • Disconnect the black and white coaxial cables from the Wi-Fi card.
    • Remove the Wi-Fi card from its port.
  12. Dell Inspiron 15 7579 Display Replacement: adım 12, 2 resimden 1. Dell Inspiron 15 7579 Display Replacement: adım 12, 2 resimden 2.
    • Remove the two screws from the metal plates with the Phillips #0 screwdriver.
  13. Dell Inspiron 15 7579 Display Replacement: adım 13, 3 resimden 1. Dell Inspiron 15 7579 Display Replacement: adım 13, 3 resimden 2. Dell Inspiron 15 7579 Display Replacement: adım 13, 3 resimden 3.
    • Lift up the two hinges perpendicularly to the board beneath it.
    • It may be difficult to lift up the hinges, so it may take some force to remove them.
    • Lift up on the keyboard at an angle from the laptop and gently pull away from hinges.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 32
Her zaman: 1,102
