Ana içeriğe geç
Dell Inspiron 15 7579 Fan Replacement
Neye ihtiyacın var
  1. Dell Inspiron 15 7579 Fan Replacement, Back Panel: adım 1, 1 resimden 1.
    • Remove the ten 7.9 mm screws with the Phillips PH0 screwdriver.
  2. Dell Inspiron 15 7579 Fan Replacement: adım 2, 2 resimden 1. Dell Inspiron 15 7579 Fan Replacement: adım 2, 2 resimden 2.
    • Insert metal spudger into a gap in between the back panel and the back of the screen.
    • Pry off the back panel using the metal spudger as a lever, and remove the back panel by lifting the rest off by hand.
  3. Dell Inspiron 15 7579 Fan Replacement, Fan: adım 3, 2 resimden 1. Dell Inspiron 15 7579 Fan Replacement, Fan: adım 3, 2 resimden 2.
    • Remove the two 7.9 mm screws from the fan with a Phillips #0 screwdriver.
  4. Dell Inspiron 15 7579 Fan Replacement: adım 4, 2 resimden 1. Dell Inspiron 15 7579 Fan Replacement: adım 4, 2 resimden 2.
    • Unplug the wires from the port.
    • Be sure to pull from the plastic connector, not the wires.
  5. Dell Inspiron 15 7579 Fan Replacement: adım 5, 1 resimden 1.
    • Carefully lift the fan out of the computer.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 11
Her zaman: 225
