Ana içeriğe geç
Dell Inspiron 15 7579 Motherboard Replacement
Neye ihtiyacın var
  1. Dell Inspiron 15 7579 Motherboard Replacement, Back Panel: adım 1, 1 resimden 1.
    • Remove the ten 7.9 mm screws with the Phillips PH0 screwdriver.
  2. Dell Inspiron 15 7579 Motherboard Replacement: adım 2, 2 resimden 1. Dell Inspiron 15 7579 Motherboard Replacement: adım 2, 2 resimden 2.
    • Insert metal spudger into a gap in between the back panel and the back of the screen.
    • Pry off the back panel using the metal spudger as a lever, and remove the back panel by lifting the rest off by hand.
  3. Dell Inspiron 15 7579 Motherboard Replacement, Fan: adım 3, 2 resimden 1. Dell Inspiron 15 7579 Motherboard Replacement, Fan: adım 3, 2 resimden 2.
    • Remove the two 7.9 mm screws from the fan with a Phillips #0 screwdriver.
  4. Dell Inspiron 15 7579 Motherboard Replacement: adım 4, 2 resimden 1. Dell Inspiron 15 7579 Motherboard Replacement: adım 4, 2 resimden 2.
    • Unplug the wires from the port.
    • Be sure to pull from the plastic connector, not the wires.
  5. Dell Inspiron 15 7579 Motherboard Replacement: adım 5, 1 resimden 1.
    • Carefully lift the fan out of the computer.
  6. Dell Inspiron 15 7579 Motherboard Replacement, SSD M.2 Drive: adım 6, 1 resimden 1.
    • Remove the single 3.6 mm screw holding the left side of the M.2 SSD card with a Phillips PH0 screwdriver.
  7. Dell Inspiron 15 7579 Motherboard Replacement: adım 7, 1 resimden 1.
    • Gently pull out the SSD card at the angle it is relaxed in to remove it. It is easiest to do this by hand.
    • Be gentle when pulling the SSD card out. It should take little effort to get it to slide out properly.
  8. Dell Inspiron 15 7579 Motherboard Replacement, Motherboard: adım 8, 2 resimden 1. Dell Inspiron 15 7579 Motherboard Replacement, Motherboard: adım 8, 2 resimden 2.
    • Remove the six 2.1 mm screws with the Phillips #0 screwdriver.
  9. Dell Inspiron 15 7579 Motherboard Replacement: adım 9, 2 resimden 1. Dell Inspiron 15 7579 Motherboard Replacement: adım 9, 2 resimden 2.
    • Unplug the eight ribbon cables connected to the motherboard.
  10. Dell Inspiron 15 7579 Motherboard Replacement: adım 10, 1 resimden 1.
    • Lift the motherboard up from the side opposite of the external ports and remove it from the laptop.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 16
Her zaman: 506
