Ana içeriğe geç
Dell Inspiron 15 7579 RAM (Memory) Replacement
Neye ihtiyacın var
  1. Dell Inspiron 15 7579 RAM (Memory) Replacement, Back Panel: adım 1, 1 resimden 1.
    • Remove the ten 7.9 mm screws with the Phillips PH0 screwdriver.
  2. Dell Inspiron 15 7579 RAM (Memory) Replacement: adım 2, 2 resimden 1. Dell Inspiron 15 7579 RAM (Memory) Replacement: adım 2, 2 resimden 2.
    • Insert metal spudger into a gap in between the back panel and the back of the screen.
    • Pry off the back panel using the metal spudger as a lever, and remove the back panel by lifting the rest off by hand.
  3. Dell Inspiron 15 7579 RAM (Memory) Replacement, RAM (Memory): adım 3, 1 resimden 1.
    • Fold protective flaps to the side on the RAM module located in the upper right corner of the laptop.
  4. Dell Inspiron 15 7579 RAM (Memory) Replacement: adım 4, 3 resimden 1. Dell Inspiron 15 7579 RAM (Memory) Replacement: adım 4, 3 resimden 2. Dell Inspiron 15 7579 RAM (Memory) Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Use the tweezers to push the crimping metal away from the chip. The chip will pop up into an angled position.
    • Remove the chip by pulling at the same angle as the chip with the tweezers.
  5. Dell Inspiron 15 7579 RAM (Memory) Replacement: adım 5, 3 resimden 1. Dell Inspiron 15 7579 RAM (Memory) Replacement: adım 5, 3 resimden 2. Dell Inspiron 15 7579 RAM (Memory) Replacement: adım 5, 3 resimden 3.
    • Fold the plastic flap over on the other side.
    • As before, pull the fasteners away from the chip with the tweezers.
    • Remove the chip by carefully pulling it out with the tweezers.
  6. Dell Inspiron 15 7579 RAM (Memory) Replacement: adım 6, 2 resimden 1. Dell Inspiron 15 7579 RAM (Memory) Replacement: adım 6, 2 resimden 2.
    • When reassembling, you must match the notch in the card with the notch in the connector header shown in red.
    • Doing otherwise will break the stick if forced.
Sonuç
Inaki Madrigal
760 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S24-G9, Maness Spring 2018 Cal Poly, Team S24-G9, Maness Spring 2018 üyesi
CPSU-MANESS-S18S24G9
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 14
Her zaman: 711
