Ana içeriğe geç
Dell Inspiron 15 7590 2-in-1 Keys Replacement
Neye ihtiyacın var
  1. Dell Inspiron 15 7590 2-in-1 Keys Replacement, Keys: adım 1, 2 resimden 1. Dell Inspiron 15 7590 2-in-1 Keys Replacement, Keys: adım 1, 2 resimden 2.
    • Position a spudger between the key cap and its hinge.
    • Push up with steady force to snap the key cap away from the hinge.
    • Use a spudger to pry under the corners of the hinge to remove it.
    • Remember the orientation of your key hinge and which holes go to the upper metal holders.
  2. Dell Inspiron 15 7590 2-in-1 Keys Replacement: adım 2, 2 resimden 1. Dell Inspiron 15 7590 2-in-1 Keys Replacement: adım 2, 2 resimden 2.
    • Align the new hinge with the metal holders on the keyboard.
    • Push the hinge into place and lock it onto the metal holders.
    • Make sure the hinge lies flat on the metal holders. If it doesn't, check the orientation of the hinge.
  3. Dell Inspiron 15 7590 2-in-1 Keys Replacement: adım 3, 2 resimden 1. Dell Inspiron 15 7590 2-in-1 Keys Replacement: adım 3, 2 resimden 2.
    • Flip the key cap over and determine the positions of the spikes jutting out.
    • Align the spikes with the holes on the hinge and press the key cap onto the hinge.
  4. Dell Inspiron 15 7590 2-in-1 Keys Replacement: adım 4, 1 resimden 1.
    • Press down on the key to snap it into place.
  5. Dell Inspiron 15 7590 2-in-1 Keys Replacement: adım 5, 3 resimden 1. Dell Inspiron 15 7590 2-in-1 Keys Replacement: adım 5, 3 resimden 2. Dell Inspiron 15 7590 2-in-1 Keys Replacement: adım 5, 3 resimden 3.
    • To replace big keys, examine the other side of the key cap and locate the metal wires attached to the holders on the back of the key.
    • Examine the space the key will enter, and locate the metal holders with holes in them.
    • Position the key so all the metal ends can enter a hole and insert the metal ends into the holes.
    • Push down on the key and adjust the keycap to make sure its metal attachments slide into their holders.
Sonuç
If you encountered unsolvable difficulties replacing a key, make sure it’s aligned properly and crosscheck that the key is the same model as your laptop.
Ojonukpemi F Ameh
121 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 19
Son 30 gün: 93
Her zaman: 2,451
