Ana içeriğe geç
Dell Inspiron 15 7591 2-in-1 Battery Replacement
Neye ihtiyacın var
  1. Dell Inspiron 15 7591 2-in-1 Battery Replacement, Opening the Laptop: adım 1, 2 resimden 1. Dell Inspiron 15 7591 2-in-1 Battery Replacement, Opening the Laptop: adım 1, 2 resimden 2.
    • Unscrew the 7 Philips #000 screws.
    • Loosen the 2 Philips #000 screws. These screws do not come out but rather stay attached to the case.
    • With a suction cup lift the top and insert a plastic pry tool or guitar pick. Slide the pry tool from left to right. The panel should pop out slightly.
    • Work downwards with a pry tool on the right and left sides. The panel should pop up and be able to be removed.
  2. Dell Inspiron 15 7591 2-in-1 Battery Replacement, Removing the Battery: adım 2, 1 resimden 1.
    • Remove the 2 Philips #000 screws.
    • Loosen the Philips #000 screws. The screw is attached to the battery and will remain attached to the battery.
  3. Dell Inspiron 15 7591 2-in-1 Battery Replacement, Disconnecting the Battery: adım 3, 1 resimden 1.
    • Flip the battery upside down onto the motherboard.
    • Snake the wire out of its housing.
    • Disconnect the power connector.
  4. Dell Inspiron 15 7591 2-in-1 Battery Replacement: adım 4, 1 resimden 1.
    • Slide the battery in with the bottom first in order to attach the latches that are at the bottom.
    • Screw in the 2 Phillips #000 screws and tighten the 1 Phillips #000 screw attached to the battery.
Sonuç
To reassemble your device, follow these instructions in reverse order. When re-attaching the bottom panel be careful when tightening the screws near the trackpad. If these screws are over tightened it can prevent the trackpad from being clicked.
Griffin Nott
181 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 33
Her zaman: 976
