Giriş
In this guide, we will be showing you how to remove and replace the Display Assembly.
Neye ihtiyacın var
Using the pull-tab, disconnect the camera cable from the system board.
Note the antenna cables routing and remove the antenna cables from the routing guides on the computer base.
Remove the screw (M3x3) that secures the display-cable bracket to the system board.
Lift the display-cable bracket off the computer base.
Using the pull tab, disconnect the display cable from the system board.
Remove the display cable from the routing guides on the computer base and peel off the display cable from the computer base.
Remove the two screws (M2x3) that secure the display assembly to the computer base.
Remove the two screws (M2.5x5) that secure the display assembly to the computer base.
Align the screw holes on the NEW display assembly with the screw holes on the computer base.
Replace the two screws (M2x2.5) that secure the display assembly to the computer base.
Replace the two screws (M2x3) that secure the display assembly to the computer base.
Replace the two screws (M2.5x5) that secure the display assembly to the computer base.
Route the display cable through the routing guides on the computer base.
Adhere the display cable and the camera cable to the computer base.
Align the screw hole on display-cable bracket with the screw hole on the computer base.
Replace the screw (M3x3) that secures the display-cable bracket to the computer base.
Route the antenna cables through the routing guides on the computer base.
