Ana içeriğe geç
Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement
Neye ihtiyacın var
  1. Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement, M.2 NVMe Solid State Drive: adım 1, 2 resimden 1. Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement, M.2 NVMe Solid State Drive: adım 1, 2 resimden 2.
    • Place the laptop with the bottom panel facing up.
    • Remove the single screw to access the bottom panel.
  2. Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: adım 2, 3 resimden 1. Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: adım 2, 3 resimden 2. Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: adım 2, 3 resimden 3.
    • Place a finger under the screw location and move it around the edge to pry the fourteen clips out.
    • There are six clips on each side of the panel and two on the edge by the screw.
    • Remove the bottom panel.
  3. Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: adım 3, 3 resimden 1. Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: adım 3, 3 resimden 2. Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: adım 3, 3 resimden 3.
    • Locate the M.2 drive to the right of the battery, below the hard drive.
    • Remove the screw on the edge of the drive.
  4. Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: adım 4, 3 resimden 1. Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: adım 4, 3 resimden 2. Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: adım 4, 3 resimden 3.
    • Lift up on the edge of the drive where the screw was.
    • Grab the drive by the two long edges.
    • Pull the drive out.
    • Note the keying on your new drive; it will only go in one way.
  5. Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: adım 5, 3 resimden 1. Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: adım 5, 3 resimden 2. Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: adım 5, 3 resimden 3.
    • Angle the new drive and insert it into the slot.
    • Apply pressure down on the screw end of the drive.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 22
Her zaman: 3,406
