Ana içeriğe geç
Dell Inspiron 15 Ram (Memory Module) Replacement
Neye ihtiyacın var
  1. Dell Inspiron 15 Ram (Memory Module) Replacement, Battery: adım 1, 2 resimden 1. Dell Inspiron 15 Ram (Memory Module) Replacement, Battery: adım 1, 2 resimden 2.
    • Make sure your laptop is powered off completely and is not connected to the charger.
    • Close the laptop and place it so that the back of the screen is lying flat on your work surface.
    • Slide both of the battery-release latches towards the outer edges of the laptop to unlock the battery flap.
    FixBot'a Sor
    Yorum Ekle
  2. Dell Inspiron 15 Ram (Memory Module) Replacement: adım 2, 1 resimden 1.
    • Lift the battery at an angle using your fingertips and remove it from the laptop.
    • Press and hold the power button for 5 seconds. This ensures that any remaining power will drain out of the computer.
    FixBot'a Sor
    Yorum Ekle
  3. Dell Inspiron 15 Ram (Memory Module) Replacement, Ram  (Memory Module): adım 3, 3 resimden 1. Dell Inspiron 15 Ram (Memory Module) Replacement, Ram  (Memory Module): adım 3, 3 resimden 2. Dell Inspiron 15 Ram (Memory Module) Replacement, Ram  (Memory Module): adım 3, 3 resimden 3.
    • Remove the bottom cover by removing the 4 mm screw using a PH-0 Phillips screwdriver that secures the base cover to the laptop base.
    • Using the plastic opening tool, pry the base cover from the base.
    • Slide the base cover towards you and remove it from the base. Put it aside.
    FixBot'a Sor
    Yorum Ekle
  4. Dell Inspiron 15 Ram (Memory Module) Replacement: adım 4, 3 resimden 1. Dell Inspiron 15 Ram (Memory Module) Replacement: adım 4, 3 resimden 2. Dell Inspiron 15 Ram (Memory Module) Replacement: adım 4, 3 resimden 3.
    • Using your fingertips, pry the vertical sides of the memory module apart until the piece pops out of place.
    • Slide the memory module out of its slot and lift it out of the laptop base.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Edward Pacheco
852 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-8, Landers Spring 2016 UMass Dartmouth, Team 5-8, Landers Spring 2016 üyesi
UMASSD-LANDERS-S16S5G8
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 48
Her zaman: 7,373
