Ana içeriğe geç
Dell Inspiron 15-3521 Hard Drive Replacement
Neye ihtiyacın var
  1. Dell Inspiron 15-3521 Hard Drive Replacement, Removing the Battery: adım 1, 3 resimden 1. Dell Inspiron 15-3521 Hard Drive Replacement, Removing the Battery: adım 1, 3 resimden 2. Dell Inspiron 15-3521 Hard Drive Replacement, Removing the Battery: adım 1, 3 resimden 3.
    • We are removing the battery to avoid the possibility of an electrical discharge when working with this system.
    • Flip the laptop over.
    • Slide the latches toward the outside of the laptop to unlock the battery.
    • Lift the battery out of the laptop.
  2. Dell Inspiron 15-3521 Hard Drive Replacement, Removing the Access Panel: adım 2, 3 resimden 1. Dell Inspiron 15-3521 Hard Drive Replacement, Removing the Access Panel: adım 2, 3 resimden 2. Dell Inspiron 15-3521 Hard Drive Replacement, Removing the Access Panel: adım 2, 3 resimden 3.
    • Loosen the two screws attaching the access door to the laptop body.
    • Using a spudger, pry open the access door from the laptop.
    • Using your fingers, open and remove the access door from the laptop, exposing the memory cards underneath.
  3. Dell Inspiron 15-3521 Hard Drive Replacement, Remove the Hard Drive: adım 3, 3 resimden 1. Dell Inspiron 15-3521 Hard Drive Replacement, Remove the Hard Drive: adım 3, 3 resimden 2. Dell Inspiron 15-3521 Hard Drive Replacement, Remove the Hard Drive: adım 3, 3 resimden 3.
    • Locate the two hard drive screws, located on the left-hand side of the hard drive casing.
    • Loosen and remove these screws using a phillips head screw driver PH0.
    • Push the hard drive to the left, and then lift out of the laptop casing to remove from laptop.
  4. Dell Inspiron 15-3521 Hard Drive Replacement, Accessing Hard Drive: adım 4, 3 resimden 1. Dell Inspiron 15-3521 Hard Drive Replacement, Accessing Hard Drive: adım 4, 3 resimden 2. Dell Inspiron 15-3521 Hard Drive Replacement, Accessing Hard Drive: adım 4, 3 resimden 3.
    • Identify the Hard Drive caddy screws, one on each side of the hard drive casing.
    • Remove these screws using a phillips head PH0 screwdriver.
    • Now, with a new hard drive, attach the caddy/casing using the same screws removed from the old hard drive.
Sonuç
28 farklı kişi bu kılavuzu tamamladı.
Andrew Dippre
2.902 İtibar
7 adet Kılavuz yazıldı
Ekip
Clemson, Team 3-1, Benson Fall 2014 Clemson, Team 3-1, Benson Fall 2014 üyesi
CLEM-BENSON-F14S3G1
4 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 49
Her zaman: 32,796
