Ana içeriğe geç
Dell Inspiron 15-3521 RAM Replacement
Neye ihtiyacın var
  1. Dell Inspiron 15-3521 RAM Replacement, Remove the battery: adım 1, 3 resimden 1. Dell Inspiron 15-3521 RAM Replacement, Remove the battery: adım 1, 3 resimden 2. Dell Inspiron 15-3521 RAM Replacement, Remove the battery: adım 1, 3 resimden 3.
    • We are removing the battery to avoid the possibility of an electrical discharge when working with this system.
    • Flip the laptop over.
    • Slide the latches toward the outside of the laptop to unlock the battery.
    • Lift the battery out of the laptop.
  2. Dell Inspiron 15-3521 RAM Replacement, Remove access door: adım 2, 3 resimden 1. Dell Inspiron 15-3521 RAM Replacement, Remove access door: adım 2, 3 resimden 2. Dell Inspiron 15-3521 RAM Replacement, Remove access door: adım 2, 3 resimden 3.
    • Loosen the two screws attaching the access door to the laptop body
    • Using a spudger, pry open the access door from the laptop
    • Using your fingers, open and remove the access door from the laptop, exposing the memory cards underneath.
  3. Dell Inspiron 15-3521 RAM Replacement, Memory Card Removal/Replacement: adım 3, 3 resimden 1. Dell Inspiron 15-3521 RAM Replacement, Memory Card Removal/Replacement: adım 3, 3 resimden 2. Dell Inspiron 15-3521 RAM Replacement, Memory Card Removal/Replacement: adım 3, 3 resimden 3.
    • To access the memory cards, push out the latches on the left and right of the memory cards
    • To remove the memory card, pull it out of the tray with the latches still stretched out
    • Insert a new memory card in to the memory card tray, depressing until side latches engage with a click.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Andrew Dippre
2.920 İtibar
7 adet Kılavuz yazıldı
Ekip
Clemson, Team 3-1, Benson Fall 2014 Clemson, Team 3-1, Benson Fall 2014 üyesi
CLEM-BENSON-F14S3G1
4 Üyeler
9 adet Kılavuz yazıldı
1Rehber Yorum
I don't understand
Dorcas Logant - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 23
Her zaman: 6,625
