Ana içeriğe geç
Dell Inspiron 15-3521 Wireless Card Replacement
Neye ihtiyacın var
  1. Dell Inspiron 15-3521 Wireless Card Replacement, Remove the Battery: adım 1, 3 resimden 1. Dell Inspiron 15-3521 Wireless Card Replacement, Remove the Battery: adım 1, 3 resimden 2. Dell Inspiron 15-3521 Wireless Card Replacement, Remove the Battery: adım 1, 3 resimden 3.
    • Flip the laptop over.
    • Slide the latches toward the outside of the laptop to unlock the battery.
    • Lift the battery out of the laptop.
  2. Dell Inspiron 15-3521 Wireless Card Replacement, Removing Keyboard: adım 2, 3 resimden 1. Dell Inspiron 15-3521 Wireless Card Replacement, Removing Keyboard: adım 2, 3 resimden 2. Dell Inspiron 15-3521 Wireless Card Replacement, Removing Keyboard: adım 2, 3 resimden 3.
    • Flip laptop right side up
    • Using a flat head screwdriver, depress locking tabs holding keyboard into place
    • Using a spudger, pry the keyboard from the laptop, giving room to access with hands.
    • Using hands, remove keyboard completely from laptop body, leaving only the connecting cord that attaches the keyboard to the laptop.
  3. Dell Inspiron 15-3521 Wireless Card Replacement, Disconnecting the Keyboard Cable: adım 3, 3 resimden 1. Dell Inspiron 15-3521 Wireless Card Replacement, Disconnecting the Keyboard Cable: adım 3, 3 resimden 2. Dell Inspiron 15-3521 Wireless Card Replacement, Disconnecting the Keyboard Cable: adım 3, 3 resimden 3.
    • To disconnect the keyboard, locate the keyboard cable locking mechanism.
    • Open the locking mechanism by gently pulling up.
    • Slide out the keyboard cable from the interface to separate the keyboard form the laptop.
  4. Dell Inspiron 15-3521 Wireless Card Replacement, Wireless Card Removal: adım 4, 3 resimden 1. Dell Inspiron 15-3521 Wireless Card Replacement, Wireless Card Removal: adım 4, 3 resimden 2. Dell Inspiron 15-3521 Wireless Card Replacement, Wireless Card Removal: adım 4, 3 resimden 3.
    • Remove the wireless card cables powering the wireless card
    • Unscrew the wireless card using a PH0 screwdriver.
    • Replace with a new wireless card, reattaching the power cables.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Andrew Dippre
2.902 İtibar
7 adet Kılavuz yazıldı
Ekip
Clemson, Team 3-1, Benson Fall 2014 Clemson, Team 3-1, Benson Fall 2014 üyesi
CLEM-BENSON-F14S3G1
4 Üyeler
9 adet Kılavuz yazıldı
2 Yorum
On an Insperion 15 model 3878, the Wi-Fi adapter wasn't under the keyboard. It was under the inset cover on the bottom.
I reseated the card connection and then Windows could communicate to configure it.
Student4Life - Yanıt
its wlan is right now 2.4ghz. i want to upgrade it to 5ghz. please suggest a solution!
rohit nair - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 32
Her zaman: 6,176
