Ana içeriğe geç
Dell Inspiron 15-3531 Hard Drive Replacement
Neye ihtiyacın var
  1. Dell Inspiron 15-3531 Hard Drive Replacement, Battery: adım 1, 3 resimden 1. Dell Inspiron 15-3531 Hard Drive Replacement, Battery: adım 1, 3 resimden 2. Dell Inspiron 15-3531 Hard Drive Replacement, Battery: adım 1, 3 resimden 3.
    • Remove the battery to avoid electrical discharge while working with this system.
    • Flip the laptop over.
    • Slide the latches toward the edges to unlock the battery.
    • Lift the battery out of the laptop.
  2. Dell Inspiron 15-3531 Hard Drive Replacement, Hard Drive: adım 2, 3 resimden 1. Dell Inspiron 15-3531 Hard Drive Replacement, Hard Drive: adım 2, 3 resimden 2. Dell Inspiron 15-3531 Hard Drive Replacement, Hard Drive: adım 2, 3 resimden 3.
    • Loosen the two screws on the access panel using the PH1 head screwdriver.
    • Pry the access panel from the laptop using the spudger.
  3. Dell Inspiron 15-3531 Hard Drive Replacement: adım 3, 2 resimden 1. Dell Inspiron 15-3531 Hard Drive Replacement: adım 3, 2 resimden 2.
    • Lift the access panel away from the laptop to reveal the hard drive on the left.
    • Remove the two 8.65 mm screws on the left side of the hard drive using the PH0 head screwdriver.
    • There is a plastic tab beneath the hard drive.
  4. Dell Inspiron 15-3531 Hard Drive Replacement: adım 4, 3 resimden 1. Dell Inspiron 15-3531 Hard Drive Replacement: adım 4, 3 resimden 2. Dell Inspiron 15-3531 Hard Drive Replacement: adım 4, 3 resimden 3.
    • Push the hard drive to the left to release it and use the tab to pull it free from the laptop. The hard drive is in a caddy.
    • Remove the two 1.22 mm screws holding the hard drive in the caddy with the PH0 head screwdriver.
Sonuç
Kody Dahlke
730 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G5, Leahy Spring 2018 USF Tampa, Team S1-G5, Leahy Spring 2018 üyesi
USFT-LEAHY-S18S1G5
5 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 997
