Ana içeriğe geç
Dell Inspiron 15-3531 Keyboard Replacement
Neye ihtiyacın var
  1. Dell Inspiron 15-3531 Keyboard Replacement, Battery: adım 1, 3 resimden 1. Dell Inspiron 15-3531 Keyboard Replacement, Battery: adım 1, 3 resimden 2. Dell Inspiron 15-3531 Keyboard Replacement, Battery: adım 1, 3 resimden 3.
    • Remove the battery to avoid electrical discharge while working with this system.
    • Flip the laptop over.
    • Slide the latches toward the edges to unlock the battery.
    • Lift the battery out of the laptop.
  2. Dell Inspiron 15-3531 Keyboard Replacement, Keyboard: adım 2, 3 resimden 1. Dell Inspiron 15-3531 Keyboard Replacement, Keyboard: adım 2, 3 resimden 2. Dell Inspiron 15-3531 Keyboard Replacement, Keyboard: adım 2, 3 resimden 3.
    • Depress (push in, not down) the five tabs at the top of the keyboard and the two on each side of the keyboard with a flat head screwdriver.
    • Pry the keyboard from the laptop using the spudger.
    • Be careful when lifting it out because there is a cable connecting the keyboard to the laptop.
  3. Dell Inspiron 15-3531 Keyboard Replacement: adım 3, 3 resimden 1. Dell Inspiron 15-3531 Keyboard Replacement: adım 3, 3 resimden 2. Dell Inspiron 15-3531 Keyboard Replacement: adım 3, 3 resimden 3.
    • Lift the latch holding down the cable using a flat head screwdriver.
    • Slide the cable out.
    • This will free the keyboard from the laptop.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Kody Dahlke
742 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G5, Leahy Spring 2018 USF Tampa, Team S1-G5, Leahy Spring 2018 üyesi
USFT-LEAHY-S18S1G5
5 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 23
Her zaman: 630
