Ana içeriğe geç
Dell Inspiron 15-3531 Motherboard Replacement
Neye ihtiyacın var
  1. Dell Inspiron 15-3531 Motherboard Replacement, Battery: adım 1, 3 resimden 1. Dell Inspiron 15-3531 Motherboard Replacement, Battery: adım 1, 3 resimden 2. Dell Inspiron 15-3531 Motherboard Replacement, Battery: adım 1, 3 resimden 3.
    • Remove the battery to avoid electrical discharge while working with this system.
    • Flip the laptop over.
    • Slide the latches toward the edges to unlock the battery.
    • Lift the battery out of the laptop.
  2. Dell Inspiron 15-3531 Motherboard Replacement, Motherboard: adım 2, 3 resimden 1. Dell Inspiron 15-3531 Motherboard Replacement, Motherboard: adım 2, 3 resimden 2. Dell Inspiron 15-3531 Motherboard Replacement, Motherboard: adım 2, 3 resimden 3.
    • Loosen the two screws on the access panel using the PH1 head screwdriver.
    • Pry the access panel open with the spudger.
  3. Dell Inspiron 15-3531 Motherboard Replacement: adım 3, 3 resimden 1. Dell Inspiron 15-3531 Motherboard Replacement: adım 3, 3 resimden 2. Dell Inspiron 15-3531 Motherboard Replacement: adım 3, 3 resimden 3.
    • Remove the memory card by pulling apart the latches holding it in place.
  4. Dell Inspiron 15-3531 Motherboard Replacement: adım 4, 1 resimden 1.
    • Remove the nine 8.65mm screws holding the backplate to the laptop using the PH0 head screwdriver.
    • Remove the four 1.22 mm screws holding the backplate to the laptop using the PH0 head screwdriver.
  5. Dell Inspiron 15-3531 Motherboard Replacement: adım 5, 3 resimden 1. Dell Inspiron 15-3531 Motherboard Replacement: adım 5, 3 resimden 2. Dell Inspiron 15-3531 Motherboard Replacement: adım 5, 3 resimden 3.
    • Depress (push in, not down) the five tabs at the top of the keyboard and the two on each side of the keyboard using a flat head screwdriver.
    • Pry the keyboard from the laptop using the spudger.
    • Be careful when lifting out the keyboard because there is a cable connecting it to the laptop.
  6. Dell Inspiron 15-3531 Motherboard Replacement: adım 6, 3 resimden 1. Dell Inspiron 15-3531 Motherboard Replacement: adım 6, 3 resimden 2. Dell Inspiron 15-3531 Motherboard Replacement: adım 6, 3 resimden 3.
    • Lift the latch holding down the cable using a flat head screwdriver.
    • Slide the cable out.
    • This will free the keyboard from the laptop.
  7. Dell Inspiron 15-3531 Motherboard Replacement: adım 7, 3 resimden 1. Dell Inspiron 15-3531 Motherboard Replacement: adım 7, 3 resimden 2. Dell Inspiron 15-3531 Motherboard Replacement: adım 7, 3 resimden 3.
    • Disengage both antenna (black and white) cables by lifting them up using the spudger.
    • Unscrew the one 8.65 mm screw holding the wireless card.
    • Remove the wireless card.
  8. Dell Inspiron 15-3531 Motherboard Replacement: adım 8, 2 resimden 1. Dell Inspiron 15-3531 Motherboard Replacement: adım 8, 2 resimden 2.
    • Lift the locking tab with the spudger and pull the cable form the locking tab.
    • Repeat with the second locking tab.
  9. Dell Inspiron 15-3531 Motherboard Replacement: adım 9, 1 resimden 1.
    • Remove the four 8.65 mm screws underneath the keyboard plate.
    • Remove the three 1.22 mm small screws underneath the keyboard plate.
  10. Dell Inspiron 15-3531 Motherboard Replacement: adım 10, 3 resimden 1. Dell Inspiron 15-3531 Motherboard Replacement: adım 10, 3 resimden 2. Dell Inspiron 15-3531 Motherboard Replacement: adım 10, 3 resimden 3.
    • Separate the palmrest from the base of the laptop using the spudger to loosen the palmrest along the edges.
    • Make sure to remove all the screws, especially the inconspicuous 8.65 mm screw next to the hard drive.
  11. Dell Inspiron 15-3531 Motherboard Replacement: adım 11, 3 resimden 1. Dell Inspiron 15-3531 Motherboard Replacement: adım 11, 3 resimden 2. Dell Inspiron 15-3531 Motherboard Replacement: adım 11, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Remove the cables on the upper left side of the laptop using flat tweezers.
    • Remove the cable from the upper right hand corner.
  12. Dell Inspiron 15-3531 Motherboard Replacement: adım 12, 2 resimden 1. Dell Inspiron 15-3531 Motherboard Replacement: adım 12, 2 resimden 2.
    • Remove the speaker cable.
    • Remove cable on the right-hand side.
  13. Dell Inspiron 15-3531 Motherboard Replacement: adım 13, 1 resimden 1.
    • Unscrew the one 8.65 mm screw holding the motherboard in place with a PH0 size head screwdriver.
    • Remove the motherboard.
Sonuç
Kody Dahlke
742 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G5, Leahy Spring 2018 USF Tampa, Team S1-G5, Leahy Spring 2018 üyesi
USFT-LEAHY-S18S1G5
5 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 28
Her zaman: 1,429
