Ana içeriğe geç
Dell Inspiron 15-3542 LCD Screen Replacement
Neye ihtiyacın var
  1. Dell Inspiron 15-3542 LCD Screen Replacement, LCD Screen: adım 1, 3 resimden 1. Dell Inspiron 15-3542 LCD Screen Replacement, LCD Screen: adım 1, 3 resimden 2. Dell Inspiron 15-3542 LCD Screen Replacement, LCD Screen: adım 1, 3 resimden 3.
    • Power off the laptop.
    • Flip the laptop over so the bottom is facing up.
    • Slide the right button to the unlock symbol.
    • Slide the left button to the other unlock symbol.
    • While holding the left button, use your right finger to raise the battery up from the laptop.
  2. Dell Inspiron 15-3542 LCD Screen Replacement: adım 2, 3 resimden 1. Dell Inspiron 15-3542 LCD Screen Replacement: adım 2, 3 resimden 2. Dell Inspiron 15-3542 LCD Screen Replacement: adım 2, 3 resimden 3.
    • Flip the laptop over so the top is facing up and open the laptop.
    • Using both hands, unsnap the tabs around the perimeter of the bezel and remove it from the laptop.
  3. Dell Inspiron 15-3542 LCD Screen Replacement: adım 3, 3 resimden 1. Dell Inspiron 15-3542 LCD Screen Replacement: adım 3, 3 resimden 2. Dell Inspiron 15-3542 LCD Screen Replacement: adım 3, 3 resimden 3.
    • Remove the four screws from the corners of the LCD using a Phillips screwdriver.
    • Lift the screen up and place it on the keyboard.
  4. Dell Inspiron 15-3542 LCD Screen Replacement: adım 4, 3 resimden 1. Dell Inspiron 15-3542 LCD Screen Replacement: adım 4, 3 resimden 2. Dell Inspiron 15-3542 LCD Screen Replacement: adım 4, 3 resimden 3.
    • Gently peel off the yellow clear tape securing the video connector.
    • Use an opening tool to flip open the video connector bracket.
    • Make sure not to force the video cable when removing it from the connector bracket.
    • Disconnect the cable from the LCD screen and remove the LCD from the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Najeemdeen Lamidi
130 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 21
Her zaman: 1,046
