Giriş
Is the hard drive in your Dell Inspiron 15-3543 failing, or has it already failed? If so, here is the guide to fix the problem by simply replacing your disk drive. All you need is the standard #0 Phillips Screwdriver head in order to remove the two screws involved with this replacement.
Neye ihtiyacın var
Flip the device over so the bottom is facing up.
Using a #0 Phillips screwdriver, remove the 2.0mm screw from the back of laptop beside the vents.
2 farklı kişi bu kılavuzu tamamladı.
