Ana içeriğe geç
Dell Inspiron 15-3543 Keyboard Replacement
Neye ihtiyacın var
  1. Dell Inspiron 15-3543 Keyboard Replacement, Keyboard: adım 1, 2 resimden 1. Dell Inspiron 15-3543 Keyboard Replacement, Keyboard: adım 1, 2 resimden 2.
    • Turn the device over and open it.
    • You will see 5 notches at the top of the keyboard.
    • Stick the end of the metal spudger between each of these notches to pry the keyboard up. Once you hear a pop sound, stop and move onto the next notch.
  2. Dell Inspiron 15-3543 Keyboard Replacement: adım 2, 2 resimden 1. Dell Inspiron 15-3543 Keyboard Replacement: adım 2, 2 resimden 2.
    • Once all five notches at the top of the keyboard are loosened, begin pulling it up from the top.
    • Pull the keyboard up slowly so you don't tear the ribbon cable out or damage it.
  3. Dell Inspiron 15-3543 Keyboard Replacement: adım 3, 2 resimden 1. Dell Inspiron 15-3543 Keyboard Replacement: adım 3, 2 resimden 2.
    • To remove the ribbon cable, use the metal spudger tool to pop the ribbon cable lock up.
    • After popping up the ribbon cable lock, you can pull the ribbon cable out.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Thanks. Could you please suggest a recommended replacement keyboard? I didn't find any branded replacement item in Amazon.
Arun Prasad - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 21
Her zaman: 1,045
