Ana içeriğe geç
Dell Inspiron 15-3543 Touchpad Replacement
Neye ihtiyacın var
  1. Dell Inspiron 15-3543 Touchpad Replacement, Touchpad: adım 1, 2 resimden 1. Dell Inspiron 15-3543 Touchpad Replacement, Touchpad: adım 1, 2 resimden 2.
    • Flip the device over so the bottom is facing up.
    • Using a #0 Phillips screwdriver, remove the 4.0mm screw to the right of the disk drive.
  2. Dell Inspiron 15-3543 Touchpad Replacement: adım 2, 2 resimden 1. Dell Inspiron 15-3543 Touchpad Replacement: adım 2, 2 resimden 2.
    • Pull the disk drive out and sit it to the side.
  3. Dell Inspiron 15-3543 Touchpad Replacement: adım 3, 2 resimden 1. Dell Inspiron 15-3543 Touchpad Replacement: adım 3, 2 resimden 2.
    • Using a #0 Phillips screwdriver, remove the 2.0mm screw from the back of the device beside the vents.
  4. Dell Inspiron 15-3543 Touchpad Replacement: adım 4, 3 resimden 1. Dell Inspiron 15-3543 Touchpad Replacement: adım 4, 3 resimden 2. Dell Inspiron 15-3543 Touchpad Replacement: adım 4, 3 resimden 3.
    • Slide the panel off by placing your hands on top and, while using a little force, sliding your hands down.
  5. Dell Inspiron 15-3543 Touchpad Replacement: adım 5, 2 resimden 1. Dell Inspiron 15-3543 Touchpad Replacement: adım 5, 2 resimden 2.
    • Using a #0 Phillips screwdriver, remove the 2.0mm screw beside the black pull tab on the hard drive to the bottom left of the device.
  6. Dell Inspiron 15-3543 Touchpad Replacement: adım 6, 2 resimden 1. Dell Inspiron 15-3543 Touchpad Replacement: adım 6, 2 resimden 2.
    • Pull the black tab up and to the left to completely remove the hard drive.
    • Sit the hard drive to the side once it is out.
  7. Dell Inspiron 15-3543 Touchpad Replacement: adım 7, 2 resimden 1. Dell Inspiron 15-3543 Touchpad Replacement: adım 7, 2 resimden 2.
    • Turn the device over and open it.
    • You will see 5 notches at the top of the keyboard.
    • Stick the end of the metal spudger between each of these notches to pry the keyboard up. Once you hear a pop sound, stop and move onto the next notch.
  8. Dell Inspiron 15-3543 Touchpad Replacement: adım 8, 2 resimden 1. Dell Inspiron 15-3543 Touchpad Replacement: adım 8, 2 resimden 2.
    • Once all five notches at the top of the keyboard are loosened, begin pulling it up from the top.
    • Pull the keyboard up slowly so you don't tear the ribbon cable out or damage it.
  9. Dell Inspiron 15-3543 Touchpad Replacement: adım 9, 2 resimden 1. Dell Inspiron 15-3543 Touchpad Replacement: adım 9, 2 resimden 2.
    • To remove the ribbon cable, use the metal spudger tool to pop the ribbon cable lock up.
    • After popping up the ribbon cable lock, you can pull the ribbon cable out and sit the keyboard to the side.
  10. Dell Inspiron 15-3543 Touchpad Replacement: adım 10, 2 resimden 1. Dell Inspiron 15-3543 Touchpad Replacement: adım 10, 2 resimden 2.
    • Push the two battery locks outwards.
  11. Dell Inspiron 15-3543 Touchpad Replacement: adım 11, 2 resimden 1. Dell Inspiron 15-3543 Touchpad Replacement: adım 11, 2 resimden 2.
    • Pull the top of the battery up and out.
    • Sit the bettery to the side once it is out.
  12. Dell Inspiron 15-3543 Touchpad Replacement: adım 12, 2 resimden 1. Dell Inspiron 15-3543 Touchpad Replacement: adım 12, 2 resimden 2.
    • Remove the following ten screws with a #0 Phillips screwdriver:
    • Two 8.0mm screws.
    • Eight 4.0mm screws.
  13. Dell Inspiron 15-3543 Touchpad Replacement: adım 13, 2 resimden 1. Dell Inspiron 15-3543 Touchpad Replacement: adım 13, 2 resimden 2.
    • Using a #0 Phillips screwdriver, remove the three 4.0mm screws on the front where the keyboard used to be.
  14. Dell Inspiron 15-3543 Touchpad Replacement: adım 14, 2 resimden 1. Dell Inspiron 15-3543 Touchpad Replacement: adım 14, 2 resimden 2.
    • On the front of the device, there will be two ribbon cables. Remove them using the following directions:
    • Pull the black cable ribbon lock up and pull the blue ribbon out using the tab.
    • Pull the white cable ribbon lock up and pull the blue ribbon out using the tab .
  15. Dell Inspiron 15-3543 Touchpad Replacement: adım 15, 3 resimden 1. Dell Inspiron 15-3543 Touchpad Replacement: adım 15, 3 resimden 2. Dell Inspiron 15-3543 Touchpad Replacement: adım 15, 3 resimden 3.
    • Using the one or two opening tools, pry the bottom of the top plate off starting underneath the headphone jack.
  16. Dell Inspiron 15-3543 Touchpad Replacement: adım 16, 2 resimden 1. Dell Inspiron 15-3543 Touchpad Replacement: adım 16, 2 resimden 2.
    • Continue going around the device and prying it open until the top panel is off.
  17. Dell Inspiron 15-3543 Touchpad Replacement: adım 17, 2 resimden 1. Dell Inspiron 15-3543 Touchpad Replacement: adım 17, 2 resimden 2.
    • On the inside of the top panel, pull the black ribbon cable lock up and pull the ribbon cable out using the tab.
  18. Dell Inspiron 15-3543 Touchpad Replacement: adım 18, 2 resimden 1. Dell Inspiron 15-3543 Touchpad Replacement: adım 18, 2 resimden 2.
    • Using a #0 Phillips screwdriver, remove the three 1.0mm screws.
  19. Dell Inspiron 15-3543 Touchpad Replacement: adım 19, 2 resimden 1. Dell Inspiron 15-3543 Touchpad Replacement: adım 19, 2 resimden 2.
    • Pull the metal plate up and out from the top.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 35
Her zaman: 1,324
