Ana içeriğe geç
Dell Inspiron 15-5547 RAM Replacement
Neye ihtiyacın var
  1. Dell Inspiron 15-5547 RAM Replacement, RAM: adım 1, 2 resimden 1. Dell Inspiron 15-5547 RAM Replacement, RAM: adım 1, 2 resimden 2.
    • Remove the two M2.5 x 5mm screws on the bottom of the laptop with the Phillips #0 screwdriver as shown.
  2. Dell Inspiron 15-5547 RAM Replacement: adım 2, 2 resimden 1. Dell Inspiron 15-5547 RAM Replacement: adım 2, 2 resimden 2.
    • Use the Jimmy to pry off the back cover of the laptop.
    • Carefully lift and remove the back cover of the laptop.
  3. Dell Inspiron 15-5547 RAM Replacement: adım 3, 3 resimden 1. Dell Inspiron 15-5547 RAM Replacement: adım 3, 3 resimden 2. Dell Inspiron 15-5547 RAM Replacement: adım 3, 3 resimden 3.
    • The RAM components of the laptop can be found in the following locations.
    • Pull the two side brackets of the bottom RAM component horizontally. This will free the component.
    • Lift and remove the RAM component from its location.
    • Be careful with the RAM components as they are fragile.
  4. Dell Inspiron 15-5547 RAM Replacement: adım 4, 2 resimden 1. Dell Inspiron 15-5547 RAM Replacement: adım 4, 2 resimden 2.
    • Repeat the previous steps for the top RAM slot.
    • Apply slight pressure onto the RAM to lock it in during the reassembly.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Keegan Tucker
256 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S1-G3, Harley Summer 2019 IUPUI, Team S1-G3, Harley Summer 2019 üyesi
IUPUI-HARLEY-SU19S1G3
3 Üyeler
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 843
