Ana içeriğe geç
Dell Inspiron 15-5548 Battery Replacement
Neye ihtiyacın var
  1. Dell Inspiron 15-5548 Battery Replacement, Battery: adım 1, 3 resimden 1. Dell Inspiron 15-5548 Battery Replacement, Battery: adım 1, 3 resimden 2. Dell Inspiron 15-5548 Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Make sure the computer is unplugged and turned off before you start this procedure.
    • Look on the bottom of the computer. Locate the 2 screws. (Picture 1)
    • Using the Phillips 00 Screwdriver, unscrew both screws, and remove the bottom cover. The bottom cover can be hard to pull off, so you may need to pry it off with a pry tool.
  2. Dell Inspiron 15-5548 Battery Replacement: adım 2, 2 resimden 1. Dell Inspiron 15-5548 Battery Replacement: adım 2, 2 resimden 2.
    • Locate the large black battery.
    • Locate the 4 screws on the battery, and remove them using the Philips 00 Screwdriver.
  3. Dell Inspiron 15-5548 Battery Replacement: adım 3, 2 resimden 1. Dell Inspiron 15-5548 Battery Replacement: adım 3, 2 resimden 2.
    • Pull up on the release tab.
    • Remove the battery.
Sonuç
To reassemble your device and add in a new battery, follow these instructions in reverse order.
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 12
Her zaman: 3,873
