Ana içeriğe geç
Dell Inspiron 15-5548 RAM Replacement
Neye ihtiyacın var
  1. Dell Inspiron 15-5548 RAM Replacement, RAM: adım 1, 3 resimden 1. Dell Inspiron 15-5548 RAM Replacement, RAM: adım 1, 3 resimden 2. Dell Inspiron 15-5548 RAM Replacement, RAM: adım 1, 3 resimden 3.
    • Unplug and power off the laptop.
    • Turn the laptop over so that the grill for the fans is at the top. Locate the two screws above the grill.
    • Remove the screws with a Phillips 00 Screwdriver.
  2. Dell Inspiron 15-5548 RAM Replacement: adım 2, 2 resimden 1. Dell Inspiron 15-5548 RAM Replacement: adım 2, 2 resimden 2.
    • Use the iFixit opening tool to lift up on the casing and remove it from the laptop.
  3. Dell Inspiron 15-5548 RAM Replacement: adım 3, 3 resimden 1. Dell Inspiron 15-5548 RAM Replacement: adım 3, 3 resimden 2. Dell Inspiron 15-5548 RAM Replacement: adım 3, 3 resimden 3.
    • Locate the RAM sticks on the left side of the device.
    • On both ends of the RAM stick, pull the metal tabs away from each other.
    • The RAM stick will pop up. Gently pull the RAM stick out.
Sonuç
Jacob Cotton
101 İtibar
1 Kılavuz yazıldı
Bir Yorum
Hi Mr Cotton. Greetings. I have a Dell Inspiron 5548. Can I replace the present 8GB ram with 32GB in any type of DDR4 laptop ram?
Please respond to lucien395@gmail.com
Thank you
George Livingstone - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 16
Her zaman: 786
