Ana içeriğe geç
Dell Inspiron 15-5552 CD-Drive Replacement
Neye ihtiyacın var
  1. Dell Inspiron 15-5552 CD-Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure the laptop is powered down before you remove the battery.
  2. Dell Inspiron 15-5552 CD-Drive Replacement: adım 2, 1 resimden 1.
    • Locate the battery release switch on the bottom of the laptop.
  3. Dell Inspiron 15-5552 CD-Drive Replacement: adım 3, 1 resimden 1.
    • Slide the battery release switch away from the lock symbol towards the “unlock” position.
    • You can tell that the battery is unlocked once you hear a "click."
  4. Dell Inspiron 15-5552 CD-Drive Replacement: adım 4, 2 resimden 1. Dell Inspiron 15-5552 CD-Drive Replacement: adım 4, 2 resimden 2.
    • Rotate the battery outward by lifting the bottom lip that pops out.
    • Continue rotating the battery towards the top of the laptop until the battery is completely removed.
  5. Dell Inspiron 15-5552 CD-Drive Replacement, Keyboard: adım 5, 2 resimden 1. Dell Inspiron 15-5552 CD-Drive Replacement, Keyboard: adım 5, 2 resimden 2.
    • Keyboard
    • Insert a spudger next to the 5 plastic indents located at the top of the keyboard and gently pry to release the securing clips.
  6. Dell Inspiron 15-5552 CD-Drive Replacement: adım 6, 2 resimden 1. Dell Inspiron 15-5552 CD-Drive Replacement: adım 6, 2 resimden 2.
    • Lift the keyboard off of the computer. *Be careful not to tear the ribbon that attaches the back of the keyboard to the computer when lifting it.*
  7. Dell Inspiron 15-5552 CD-Drive Replacement: adım 7, 1 resimden 1.
    • Flip the keyboard over onto the palm-rest assembly.
  8. Dell Inspiron 15-5552 CD-Drive Replacement: adım 8, 2 resimden 1. Dell Inspiron 15-5552 CD-Drive Replacement: adım 8, 2 resimden 2.
    • Flip the black securing bar near the base of the ribbon with a spudger to release the ribbon from the computer.
  9. Dell Inspiron 15-5552 CD-Drive Replacement, CD-Drive: adım 9, 1 resimden 1.
    • CD-Drive
    • Flip the computer over, *screen down* and unscrew the 1 screw in the middle located below the battery with a J0 bit tipped screwdriver.
  10. Dell Inspiron 15-5552 CD-Drive Replacement: adım 10, 1 resimden 1.
    • Next using the J0 bit tipped screwdriver unscrew the 2 remaining screws shown in the picture.
  11. Dell Inspiron 15-5552 CD-Drive Replacement: adım 11, 2 resimden 1. Dell Inspiron 15-5552 CD-Drive Replacement: adım 11, 2 resimden 2.
    • After all 3 screws are removed take a spudger and pry the CD-Drive out of the computer.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 27
Her zaman: 201
