Ana içeriğe geç
Dell Inspiron 15-5552 Hard Drive Replacement
Neye ihtiyacın var
  1. Dell Inspiron 15-5552 Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure the laptop is powered down before you remove the battery.
  2. Dell Inspiron 15-5552 Hard Drive Replacement: adım 2, 1 resimden 1.
    • Locate the battery release switch on the bottom of the laptop.
  3. Dell Inspiron 15-5552 Hard Drive Replacement: adım 3, 1 resimden 1.
    • Slide the battery release switch away from the lock symbol towards the “unlock” position.
    • You can tell that the battery is unlocked once you hear a "click."
  4. Dell Inspiron 15-5552 Hard Drive Replacement: adım 4, 2 resimden 1. Dell Inspiron 15-5552 Hard Drive Replacement: adım 4, 2 resimden 2.
    • Rotate the battery outward by lifting the bottom lip that pops out.
    • Continue rotating the battery towards the top of the laptop until the battery is completely removed.
  5. Dell Inspiron 15-5552 Hard Drive Replacement, Hard Drive: adım 5, 2 resimden 1. Dell Inspiron 15-5552 Hard Drive Replacement, Hard Drive: adım 5, 2 resimden 2.
    • Use a JIS #0 screwdriver to unscrew the two 6 mm screws from the back panel.
    • Make sure your device is powered down and unplugged before beginning the replacement.
  6. Dell Inspiron 15-5552 Hard Drive Replacement: adım 6, 2 resimden 1. Dell Inspiron 15-5552 Hard Drive Replacement: adım 6, 2 resimden 2.
    • Using a spudger, lightly lift the RAM cover up and at an angle, away from the computer.
  7. Dell Inspiron 15-5552 Hard Drive Replacement: adım 7, 1 resimden 1.
    • Remove the four 6 mm JIS #0 screws from the hard drive.
  8. Dell Inspiron 15-5552 Hard Drive Replacement: adım 8, 1 resimden 1.
    • Lift hard drive out of the computer slightly.
    • Be careful not to tear the ribbon that attaches the hard drive to the computer when lifting it.
  9. Dell Inspiron 15-5552 Hard Drive Replacement: adım 9, 2 resimden 1. Dell Inspiron 15-5552 Hard Drive Replacement: adım 9, 2 resimden 2.
    • Using two fingers, grab the black connector on the ribbon, and pull until detached.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 5
Son 30 gün: 23
Her zaman: 452
