Ana içeriğe geç
Dell Inspiron 15-5552 Memory Replacement
Neye ihtiyacın var
  1. Dell Inspiron 15-5552 Memory Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure the laptop is powered down before you remove the battery.
  2. Dell Inspiron 15-5552 Memory Replacement: adım 2, 1 resimden 1.
    • Locate the battery release switch on the bottom of the laptop.
  3. Dell Inspiron 15-5552 Memory Replacement: adım 3, 1 resimden 1.
    • Slide the battery release switch away from the lock symbol towards the “unlock” position.
    • You can tell that the battery is unlocked once you hear a "click."
  4. Dell Inspiron 15-5552 Memory Replacement: adım 4, 2 resimden 1. Dell Inspiron 15-5552 Memory Replacement: adım 4, 2 resimden 2.
    • Rotate the battery outward by lifting the bottom lip that pops out.
    • Continue rotating the battery towards the top of the laptop until the battery is completely removed.
  5. Dell Inspiron 15-5552 Memory Replacement, Screw Location: adım 5, 1 resimden 1.
    • Flip the device on its back, locate the screws circled.
  6. Dell Inspiron 15-5552 Memory Replacement, Screw Removal: adım 6, 1 resimden 1.
    • Use a J0 screwdriver to unscrew the two, 6mm Phillips screw on the rear-cover.
  7. Dell Inspiron 15-5552 Memory Replacement, Removing Cover: adım 7, 3 resimden 1. Dell Inspiron 15-5552 Memory Replacement, Removing Cover: adım 7, 3 resimden 2. Dell Inspiron 15-5552 Memory Replacement, Removing Cover: adım 7, 3 resimden 3.
    • Using a spudger, Lightly lift the rear-cover up and at an angle, away from the computer.
  8. Dell Inspiron 15-5552 Memory Replacement, RAM Removal: adım 8, 2 resimden 1. Dell Inspiron 15-5552 Memory Replacement, RAM Removal: adım 8, 2 resimden 2.
    • Use your fingers to carefully pull the securing clips on the RAM away from each other.
    • The RAM should pop up when the clips are released.
  9. Dell Inspiron 15-5552 Memory Replacement, RAM Removal Contiuned: adım 9, 2 resimden 1. Dell Inspiron 15-5552 Memory Replacement, RAM Removal Contiuned: adım 9, 2 resimden 2.
    • Remove the dislodged up RAM by pulling it away from the connection.
    • If it does not pop up, pry it out in a steady and straight direction.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 17
Her zaman: 329
