Ana içeriğe geç
Dell Inspiron 15-5558 Hard Drive Replacement
Neye ihtiyacın var
  1. Dell Inspiron 15-5558 Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure you turn off the device before starting.
    • Flip the device over and so the white bar code is on the right.
  2. Dell Inspiron 15-5558 Hard Drive Replacement: adım 2, 1 resimden 1.
    • Slide the battery latch all the way to the left until you hear the click and see the battery prop up.
  3. Dell Inspiron 15-5558 Hard Drive Replacement: adım 3, 2 resimden 1. Dell Inspiron 15-5558 Hard Drive Replacement: adım 3, 2 resimden 2.
    • Rotate the battery up and remove it.
  4. Dell Inspiron 15-5558 Hard Drive Replacement, Hard Drive: adım 4, 3 resimden 1. Dell Inspiron 15-5558 Hard Drive Replacement, Hard Drive: adım 4, 3 resimden 2. Dell Inspiron 15-5558 Hard Drive Replacement, Hard Drive: adım 4, 3 resimden 3.
    • Using a Phillips #0 screwdriver, unscrew the two 8mm screws from the panel.
    • Take a spudger and wedge it between the panel and the base of the device.
    • Push down on the spudger until you hear a click sound.
    • Slide the spudger along the panel and continue to push down until the panel is completely detached.
    • Remove the panel.
  5. Dell Inspiron 15-5558 Hard Drive Replacement: adım 5, 3 resimden 1. Dell Inspiron 15-5558 Hard Drive Replacement: adım 5, 3 resimden 2. Dell Inspiron 15-5558 Hard Drive Replacement: adım 5, 3 resimden 3.
    • Using the Phillips #0 screwdriver, remove the four 8mm screws holding down the hard drive.
    • Take the spudger and prop up the connector so it is no longer attached.
    • Use the spudger and prop up the hard drive and remove it.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Adam Lourenco
775 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G4, Bailey Fall 2017 UMass Dartmouth, Team S3-G4, Bailey Fall 2017 üyesi
UMASSD-BAILEY-F17S3G4
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 26
Her zaman: 4,677
