Ana içeriğe geç
Dell Inspiron 15-5558 Keyboard Replacement
Neye ihtiyacın var
    1. Dell Inspiron 15-5558 Keyboard Replacement, Battery: adım 1, 1 resimden 1.
      • Make sure you turn off the device before starting.
      • Flip the device over and so the white bar code is on the right.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Inspiron 15-5558 Keyboard Replacement: adım 2, 1 resimden 1.
      • Slide the battery latch all the way to the left until you hear the click and see the battery prop up.
      FixBot'a Sor
      Yorum Ekle
    3. Dell Inspiron 15-5558 Keyboard Replacement: adım 3, 2 resimden 1. Dell Inspiron 15-5558 Keyboard Replacement: adım 3, 2 resimden 2.
      • Rotate the battery up and remove it.
      FixBot'a Sor
      Yorum Ekle
    1. Dell Inspiron 15-5558 Keyboard Replacement, Keyboard: adım 4, 3 resimden 1. Dell Inspiron 15-5558 Keyboard Replacement, Keyboard: adım 4, 3 resimden 2. Dell Inspiron 15-5558 Keyboard Replacement, Keyboard: adım 4, 3 resimden 3.
      • Identify the two small slots along the side of the keyboard closest to the screen.
      • Wedge the spudger in the two small slots and push the spudger in and down to detach the pins.
      • Using your hands, pull the keyboard up and out.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Inspiron 15-5558 Keyboard Replacement: adım 5, 3 resimden 1. Dell Inspiron 15-5558 Keyboard Replacement: adım 5, 3 resimden 2. Dell Inspiron 15-5558 Keyboard Replacement: adım 5, 3 resimden 3.
      • At the end of the ribbon cable attaching the keyboard to the device is a bar secure.
      • Using your finger or spudger, flip the bar up and the keyboard will be freed from the device.
      FixBot'a Sor
      Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Adam Lourenco
844 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G4, Bailey Fall 2017 UMass Dartmouth, Team S3-G4, Bailey Fall 2017 üyesi
UMASSD-BAILEY-F17S3G4
3 Üyeler
50 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 34
Her zaman: 2,340
