Ana içeriğe geç
Giriş
Before removing the back panel, make sure the device is disconnected from any power source. Make sure that your battery has also been removed.
  1. Use a Phillips #1 screwdriver to remove the two 2.5x8mm screws on the back panel. Use a Phillips #1 screwdriver to remove the two 2.5x8mm screws on the back panel.
    • Use a Phillips #1 screwdriver to remove the two 2.5x8mm screws on the back panel.
  2. MacBook Pil Tamir Setleri
    Başlangıç $69.99
    Buy Now
    Başlangıç $69.99
    Buy Now
  3. Place the plastic spudger in the slot. Using the flat side of the spudger pry the back panel upward and off. Do not be afraid to use a bit of muscle, as the panel does not come off without some force.
    • Place the plastic spudger in the slot. Using the flat side of the spudger pry the back panel upward and off.
    • Do not be afraid to use a bit of muscle, as the panel does not come off without some force.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Kyla Ward
510 İtibar
4 adet Kılavuz yazıldı
Takım
Baylor, Team S5-G5, Williams Spring 2018 Baylor, Team S5-G5, Williams Spring 2018 üyesi
BU-WILLIAMS-S18S5G5
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 8
Son 30 Gün: 26
Her zaman: 463
