Giriş
Before you begin, you will need a Phillips #1 screwdriver and a black nylon spudger to complete the CD Drive removal. You will also need to remove the battery of your device before you begin.
Neye ihtiyacın var
Use the Philips #1 to remove the two (2) 2.5x8mm screws that anchor the CD Drive.
Bir başkası bu kılavuzu tamamladı.
