Ana içeriğe geç
Dell Inspiron 15-5559 Hard Drive Replacement
Neye ihtiyacın var
  1. Dell Inspiron 15-5559 Hard Drive Replacement, Back Panel: adım 1, 2 resimden 1. Dell Inspiron 15-5559 Hard Drive Replacement, Back Panel: adım 1, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove the two 2.5x8mm screws on the back panel.
  2. Dell Inspiron 15-5559 Hard Drive Replacement: adım 2, 2 resimden 1. Dell Inspiron 15-5559 Hard Drive Replacement: adım 2, 2 resimden 2.
    • Place the plastic spudger in the slot. Using the flat side of the spudger pry the back panel upward and off.
    • Do not be afraid to use a bit of muscle, as the panel does not come off without some force.
  3. Dell Inspiron 15-5559 Hard Drive Replacement, Hard Drive: adım 3, 3 resimden 1. Dell Inspiron 15-5559 Hard Drive Replacement, Hard Drive: adım 3, 3 resimden 2. Dell Inspiron 15-5559 Hard Drive Replacement, Hard Drive: adım 3, 3 resimden 3.
    • Remove each of the four (4) 2.5x8mm screws that anchor the hard drive using a Phillips #1 screwdriver.
  4. Dell Inspiron 15-5559 Hard Drive Replacement: adım 4, 1 resimden 1.
    • Use the plastic spudger to remove the hard drive conductive tape by lifting the black clasp holding it down, then pulling the conductive tape toward the left to remove it.
    • It does not take much force to remove the conductive tape. Remove it gently so that you do not damage it.
  5. Dell Inspiron 15-5559 Hard Drive Replacement: adım 5, 2 resimden 1. Dell Inspiron 15-5559 Hard Drive Replacement: adım 5, 2 resimden 2.
    • Place the plastic spudger underneath the hard drive at the indicated position.
    • Use the spudger along with your other hand to gently remove the hard drive.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Kyla Ward
649 İtibar
4 adet Kılavuz yazıldı
Ekip
Baylor, Team S5-G5, Williams Spring 2018 Baylor, Team S5-G5, Williams Spring 2018 üyesi
BU-WILLIAMS-S18S5G5
3 Üyeler
5 adet Kılavuz yazıldı
2 Yorum
The blue part came off is that important?
walterandradeconde - Yanıt
can i put this in a harddrive enclosure?
chiggly 123 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 16
Son 30 gün: 24
Her zaman: 5,466
