Ana içeriğe geç
Dell Inspiron 15-5565 Coin Cell Battery Replacement
Neye ihtiyacın var
  1. Dell Inspiron 15-5565 Coin Cell Battery Replacement, Optical Drive: adım 1, 1 resimden 1.
    • Remove the 4 mm screw that secures the optical drive bracket to the optical drive using a Phillips #00 screwdriver.
  2. Dell Inspiron 15-5565 Coin Cell Battery Replacement: adım 2, 3 resimden 1. Dell Inspiron 15-5565 Coin Cell Battery Replacement: adım 2, 3 resimden 2. Dell Inspiron 15-5565 Coin Cell Battery Replacement: adım 2, 3 resimden 3.
    • Eject the optical drive by pressing the eject button.
    • Push out the optical drive bracket using the iFixit opening tool.
  3. Dell Inspiron 15-5565 Coin Cell Battery Replacement, Back Cover: adım 3, 2 resimden 1. Dell Inspiron 15-5565 Coin Cell Battery Replacement, Back Cover: adım 3, 2 resimden 2.
    • Remove 13 8 mm screws from the bottom of the device using a Phillips #00 screwdriver.
    • Remove the single 4 mm screw from the bottom of the device using a Phillips #00 screwdriver.
    • Remove the three 4 mm screws from the optical drive slot using a Phillips #00 screwdriver.
  4. Dell Inspiron 15-5565 Coin Cell Battery Replacement: adım 4, 2 resimden 1. Dell Inspiron 15-5565 Coin Cell Battery Replacement: adım 4, 2 resimden 2.
    • Remove the back cover from the laptop.
  5. Dell Inspiron 15-5565 Coin Cell Battery Replacement, Coin Cell Battery: adım 5, 3 resimden 1. Dell Inspiron 15-5565 Coin Cell Battery Replacement, Coin Cell Battery: adım 5, 3 resimden 2. Dell Inspiron 15-5565 Coin Cell Battery Replacement, Coin Cell Battery: adım 5, 3 resimden 3.
    • Remove the coin-cell battery by carefully pulling the plug from the slot.
    • The coin-cell battery is simply plugged into the circuitry. No screws or tools are needed.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 17
Her zaman: 235
