Ana içeriğe geç
Dell Inspiron 15-5565 RAM Replacement
Neye ihtiyacın var
  1. Dell Inspiron 15-5565 RAM Replacement, Optical Drive: adım 1, 1 resimden 1.
    • Remove the 4 mm screw that secures the optical drive bracket to the optical drive using a Phillips #00 screwdriver.
  2. Dell Inspiron 15-5565 RAM Replacement: adım 2, 3 resimden 1. Dell Inspiron 15-5565 RAM Replacement: adım 2, 3 resimden 2. Dell Inspiron 15-5565 RAM Replacement: adım 2, 3 resimden 3.
    • Eject the optical drive by pressing the eject button.
    • Push out the optical drive bracket using the iFixit opening tool.
  3. Dell Inspiron 15-5565 RAM Replacement, Back Cover: adım 3, 2 resimden 1. Dell Inspiron 15-5565 RAM Replacement, Back Cover: adım 3, 2 resimden 2.
    • Remove 13 8 mm screws from the bottom of the device using a Phillips #00 screwdriver.
    • Remove the single 4 mm screw from the bottom of the device using a Phillips #00 screwdriver.
    • Remove the three 4 mm screws from the optical drive slot using a Phillips #00 screwdriver.
  4. Dell Inspiron 15-5565 RAM Replacement: adım 4, 2 resimden 1. Dell Inspiron 15-5565 RAM Replacement: adım 4, 2 resimden 2.
    • Remove the back cover from the laptop.
  5. Dell Inspiron 15-5565 RAM Replacement, RAM: adım 5, 3 resimden 1. Dell Inspiron 15-5565 RAM Replacement, RAM: adım 5, 3 resimden 2. Dell Inspiron 15-5565 RAM Replacement, RAM: adım 5, 3 resimden 3.
    • Use your fingers to pull the safety clips apart on either side of the memory module. This should make the module pop upwards.
    • Remove the module from its slot by pulling it out.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 9
Her zaman: 109
